Popping sound from rear axle after lift
  • 1872 Views
Offline slade11_98
  • 22
  • 97 Geo Tracker with performance 1.6 16 valve.
« on: June 21, 2007, 09:35:42 PM »
I just installed the coil spacer lift on my 97 Geo 2dr. Now when I drive it down the road, I hear a pop from the rear axle area. I put the 92 Crown Vic shocks on, so I know the shocks are long enough. I have checked the shocks bolts to see if they are tight and they were. Has anyone had this problem before? Any help is appreciated.
Offline TysonS
  • 383
  • www.funinbc.com
Re: Popping sound from rear axle after lift
« Reply #1 on: June 22, 2007, 07:35:37 AM »
driveshaft u-joint binding?
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #2 on: June 22, 2007, 09:07:43 AM »
When you installed the shocks, what did you do with the bottom mount? The 91-CV shocks I bought, had only the bushing, I needed to press out the metal sleave from my old Sidekick shock, and push it into the 91-CV bushing in order to make the shock snug.
Offline slade11_98
  • 22
« Reply #3 on: June 22, 2007, 09:19:15 AM »
Yeah I had to do that too.....I wondered if the Crown Vic shocks need to be stiffer for this lift, they feel pretty spongy. Maybe I should have got a stiffer shock?
Offline bzzr2
  • 1011
« Reply #4 on: June 22, 2007, 11:35:05 AM »
the shock stiffness won't cause any noise unless you are topping them out, but that makes a hard clunk sound.
09 taco reg cab short box 4x4
