Daytime Running Light Module
  • 4943 Views
Offline Uncivilized
  • 1469
    • Car Domain
« on: June 26, 2007, 06:47:36 AM »
Can someone tell me where the DRL module is in a 95 2-door?
I have no low beams at all, I'm hoping it's a fault in the DRL.
Dave
Offline Sidetracker
  • 30
Re: Daytime Running Light Module
« Reply #1 on: June 26, 2007, 06:54:32 PM »
Yep! its the DRL module.  Mine was attacheed to the ECM.  The easiest way to find it is to get a new one and look under the dash, left or the steering column.
Dave
Offline Sidetracker
  • 30
« Reply #2 on: June 26, 2007, 06:59:09 PM »
Yep!  It's the daylight running module that's causing yur problem.  On my 91 it is attached to the ECM.  The easiest way to locate it is to get a new one and then look under the dash.  It should be to the left of the steering column.
Dave
Offline bus_driver
  • 479
  • the voices tell me different things
« Reply #3 on: June 26, 2007, 09:30:51 PM »
wow you are adiment about your posts you only have to do one you know we do listen to each other. hehe
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #4 on: June 28, 2007, 06:23:36 PM »
Well, I found a large relay looking box with a harness connector plugged into it, looks to be around 8 wires, some red with stripes. The connector, as well as the connector plug is distorted from melting. I can't get them apart. Further up the the harness, there are butt connectors for every wire connected to the relay. Oh no. I'm not sure if this is even it yet, because I can't find my book to check the wire colors. I think I have some electrical problems  :-\
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #5 on: June 29, 2007, 10:19:51 AM »
I'm getting closer...
That relay box is(according to Google) the headlight relay switch.  pn#38660-56b00
I tested the relay, and it seems to be okay. The connector at the harness is burnt across 3 wires, red-white, red-blue and red-green, but none of the wires are touching. Now, I have to find out where these wires go, and hopefully find... well, something! Fun Fun!!
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #6 on: June 30, 2007, 05:46:40 PM »
There's a mechanic down the road I know through a friend & wheeling, he lets us use his shop when we need it.(we pay him with beer) I asked him today about the problem and he knew right away it was the relay box, he told me they're known to fault and I need to change the relay and the melted tail of the harness. We went through 4 parts rigs before we found one that didn't have it clipped out already. He charged me $20, I connected it in, and lo and behold they work now!
Thanks Sidetracker  ;)
