Anvil & ARB Locker?
  • 1720 Views
Rodzilla
Anvil & ARB Locker?
« on: June 27, 2007, 08:34:18 AM »
I've been searching and reading archived material for weeks and I'm still lost. I'm going to buy an anvil and use a steel 3rd out of a GV. I'm going to be running an ARB airlocker. My confusion starts with what bits and pieces will match up with each other. Can I use the 26 Spine locker (RD88) and use  GV axles and re-use my 5.125 ring&pinion set out of the original 3rd so I dont have do any gear hunting?
Now I just read that to use the RD88 in the GV that you need to use the 3rd out of a Vitara/Kick. Now I'm lost. Defeats the whole purpose of the anvil if you need to use an aluminum 3rd. Can someone shed some light on this for me. Thanks.  ???
Re: Anvil & ARB Locker?
« Reply #1 on: June 27, 2007, 09:58:05 AM »
I am not sure about the ARB applications, but I believe they are all interchangable from stock Kick housing to stock GV housing. I pulled my sidekick 5.83 gears that were mounted to a sami carrier w/ detroit ez locker and it bolted right in (with proper r&p set up). So I would think that the ARB for a stock Kick housing should work.
« Reply #2 on: June 27, 2007, 09:59:44 AM »
PM 'Bobzooki'. I believe he has the ARB in an Anvil and could give you the low down.
