where does your temp. gauge sit?
  • 12 Replies
  • 3636 Views
Offline chet
  • 556
  • Zuki time!
« on: December 02, 2004, 02:56:31 AM »
in my sidekick it is really low (close to the C mark) even when there is lots of heat coming out? defective gauge or thermostat? I was thinking about changing the thermostat just to be safe?
Any suggestions?
Offline bioniconion
  • 268
Re: where does your temp. gauge sit?
« Reply #1 on: December 02, 2004, 03:14:23 AM »
u know mine does that too. it has to run for like a good 20 minutes before it pull away from the peg while running. but after like 7 it's pushing warm air. it confuzzles me  ???
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #2 on: December 02, 2004, 03:39:37 AM »
Mine points about 1/4 of the way up from cold to hot when going downhill and will climb to just under 1/2 way when pulling up hills...
Offline jerryp58
  • 449
« Reply #3 on: December 02, 2004, 03:55:46 AM »
Are you sure there's a thermostat in it?
Could be stuck open.
I've had 160, 180 (current -- sits at about 1/4), and 193 in mine and the 160 sat pretty low (just above the gap in the line).
« Last Edit: December 02, 2004, 03:56:32 AM by jerryp58 »
Jerry
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #4 on: December 02, 2004, 04:48:45 AM »
I have a stock replacement 'stat in mine, and it rides from just a bit more then 1/4 to just a hair above 1/2. Mine starts blowing warm air about 3-5 mins after I start it in the morning.
Offline real_red_wagon
  • 226
  • Make It Hert!!!
« Reply #5 on: December 02, 2004, 12:18:46 PM »
   Mine jumps all over the place :P  but never goes higher than 1/2 doesn't matter how long its been running or not moves just about as much as the tach LOL ;D I'm not sure why and I always say I'm gonna check on it but I never do ;)
Make It Hert!!!
At Lakeview Motorsports, were wasting your time already!
Offline dwcrisp
  • 212
  • 98 Tracker 2dr, 1 1/2" spacer lift, 30X9.5 BFG MTs
« Reply #6 on: December 02, 2004, 02:01:01 PM »
Mine stays pretty much just above half.  I have to smack the dash to get it to read right after I start the engine cuz it starts out stuck until I whack the dash.  I would like it to run cooler so I may go for a thermostat change.  No doubt that a cooler running engine lasts longer specially here in Florida.
Offline ZukkinMad
  • 57
  • Whatcha Waiting For?
« Reply #7 on: December 02, 2004, 02:46:47 PM »
Use to sit just below half with the oem thermostat, changed it to a high flow thermostat, and now it takes a good 10-15mins to go quarter ways.
Zukk
1994 4dr Kick, Calmini 2' suspensin lift, RRO Coil Spacers front & rear, 2" RRO Body Lift, Super Swampers TSL SX, 15 x 8 black rims, calmini header, dynomax super turbo muffler & accel super coi
Offline explosivo
  • 3157
« Reply #8 on: December 02, 2004, 10:10:58 PM »
Mine sits right around half way... it moves depending on load/speed.
omghi2.us[/url]
Offline bandit86
  • 1641
  • elv8rguy
« Reply #9 on: December 03, 2004, 09:34:05 AM »
mine is in the instrument cluster somewhere towards the right....
no seriously, is about 3/8
Offline chet
  • 556
  • Zuki time!
« Reply #10 on: December 03, 2004, 09:43:15 AM »
haha I knew someone was going to come back with that answer! I need to do some investigating mine seems to be reading lower than normal.
« Reply #11 on: December 03, 2004, 09:13:07 PM »
Mine always rode dead center,
then I changed the T-stat to a
160* and it rides between 1/8
and 1/4, too cold for cold weather
driving, I just barely get warm
air, I think I'll switch to a 170*
and route the heater lines thru
the turbo water jackets first and
then to the heater core, that should
help warm the cab better
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #12 on: December 04, 2004, 03:19:13 AM »
My gauge sits 1/4 of the way up.  Sometime under some aggressive driving conditions, it will go a little higher but when things mellow out it comes back down.
