wtb zlink bar
  • 2484 Views
67fastback
wtb zlink bar
« on: June 30, 2007, 06:14:54 PM »
I want to know where I can get a z link bar cheap. turns out they did a spring over on my sami and they just bent the bar. the streering goes all over the place while turning.and letting go with spin back...this thing will break my arm if I do not get that fix...
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: wtb zlink bar
« Reply #1 on: June 30, 2007, 06:24:46 PM »
Bad news, 67fastback...
A Z-link isn't going to help you fix the problem you have.  What you are describing is Bumpsteer and it is caused by the change in the vertical distance between the pittman arm end of the draglink and the axle end when you installed the SPOA lift.
Check out the following thread:
http://www.zukikrawlers.com/showthread.php?t=5609&highlight=bumpsteer
Towards the bottom is a couple of animated illustrations I created that sum up what you are feeling in your steering and how to fix it.
I drove for 6 years with nothing but a Breeze draglink (much more rugged than one of those welded-together-and-braced z-links that you see all the time) before I gave up and got an OTT steering kit.
If you don't have the loot fo upgrade to an OTT system (pricing varies a bit depending on how you do it), you can live with it until money does become available.  You just have to be vigilant when driving down a rough road and at night...
« Last Edit: June 30, 2007, 06:27:06 PM by ack »
Ack
BigRedZuki
Re: wtb zlink bar
« Reply #2 on: July 01, 2007, 03:28:09 PM »
would a drop pitman arm work
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: wtb zlink bar
« Reply #3 on: July 01, 2007, 03:32:06 PM »
yep thats the bad thing about a z-bar. drop pittman arm with regular bar would help.
BigRedZuki
Re: wtb zlink bar
« Reply #4 on: July 01, 2007, 03:50:28 PM »
john1947 what did you do to get bfg krawlers under you rig
