4:1 Gears
  • 2755 Views
Offline Sidetracker
  • 30
4:1 Gears
« on: November 25, 2004, 10:57:57 PM »
I'm considering installing the 4:1 gears in my 91 Tracker from either Calmini or Rocky Road.  Anyone have any exprience with them?
Offline chet
  • 556
  • Zuki time!
Re: 4:1 Gears
« Reply #1 on: November 26, 2004, 01:56:40 AM »
don't forget trail tough! buy them now they are on sale!  :P
Offline Natebert
  • 1098
Re: 4:1 Gears
« Reply #2 on: November 26, 2004, 03:39:57 AM »
Um,
My experience is that 4.x:1 gears are great !
Re: 4:1 Gears
« Reply #3 on: November 26, 2004, 03:14:51 PM »
But, The last time I heard is they didn't  fit 92 and  older.
I could be wrong but its something to check into.
Offline 96track
  • 66
  • THESE JEEP FREAKS WILL NEVER LEARN!!!
Re: 4:1 Gears
« Reply #4 on: November 29, 2004, 09:39:39 AM »
well they fit my 96 and are they greatest thing in the world, my 16valve 1.6 auto has unbelievable power now and trail toughs are $200.00 cheaper and about a 5 hour install from start to finish, just don't use a file like they say to shim the case I used a file for about 30 minutes and then said screw it and usen the ole roto-zip with a sanding attachment and whal loa job done. good luck GET THE GEARS
96 track  2 inch susp, 3 inch body,512's, 4.24 to 1, rear locker, 31x12.50 boggers, warn 8000, custom front and rear bumbers. lined and diamond plated interior.
1988 sammy  spoa with cj's rear and rears up front, 4.16, rear locker, 31x 12.50 boggers, full cage by migoffroad .com
the silver sammy is mine, they use it as a display for there cage work.
Offline SnoFalls
  • 1358
Re: 4:1 Gears
« Reply #5 on: November 29, 2004, 11:47:58 AM »
check the garage sale too ... brian has his 4:1 up ...
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
Re: 4:1 Gears
« Reply #6 on: December 03, 2004, 03:22:31 AM »
Whitfield did an install article for them right here the zukiworld bbs. Here is the link!
http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=suzuki_talk;action=display;num=1097066148
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
Offline mbmarkyb
  • 461
    • UK Vitara
Re: 4:1 Gears
« Reply #7 on: December 03, 2004, 12:06:07 PM »
mine aer going in tomorrow tehy are calmini ones.
I have had the t case built for me as i wouldnt want to do it my self but i will fit it saturday and test it sunday will post a reply to let you know, i run 33.12.50 at mo so should be a great reduction
Markyb (UK)
UK Vitara JLX SE
