Coil Time
  • 17 Replies
  • 4567 Views
Offline Natebert
  • 1098
Re: Coil Time
« Reply #15 on: December 02, 2004, 06:03:11 AM »
So you mean that Sidekick axles(F-Hyb,R-Stock) cant be used  in a Sammy ?   too wide heh ?
I have 2 sammy buddies here in Idaho which run this setup.
Sidekick rear ends, with hybrid fronts.
(thats where we came up with the idea to put it under the Kick in the first place.)
Run the 6 inch extended jeep fender flares and it works great!
« Last Edit: December 02, 2004, 06:03:31 AM by natebert »
GRVIT
Re: Coil Time
« Reply #16 on: December 02, 2004, 07:18:35 AM »
Yes ,I like the idea very much.The only problem is that here with such set up,I wont pass the MOT..... :(
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
Re: Coil Time
« Reply #17 on: December 03, 2004, 03:19:21 AM »
Avoid the pain and the high dollar axle band-aids and throw some Yota axles under there. You will be glad you did ;D
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
