Coil Time
  • 17 Replies
  • 4566 Views
Offline suzi_n_sammy
  • 184
  • Rock the Sam
Coil Time
« on: November 27, 2004, 05:54:09 AM »
Alright,
I got a coil set up for my sammy and i need to ask a few things. I am going to run 35's so im going to beef up my axles, Im already changin the gears in there out for 5.38's so I figured Id rebuild them. So far this is what im thinking;
1)New R&P
2)Rebuild
3)Calmini axles
4)Birfeild rings
5)Side gears
So thats what im looking to do with my axles. Anybody have any suggestions? Thanks.
You can take the Sammy off the trail, but you cant take the trail out of the Sammy.
Re: Coil Time
« Reply #1 on: November 27, 2004, 06:33:51 AM »
you can foget the birfields with 35's, go over to roadless gear and look at the new front axels for only 580.00  ;D
Offline 1bigtracker
  • 3409
Re: Coil Time
« Reply #2 on: November 27, 2004, 07:13:32 AM »
might wana think about droping a tracker rear third in your sammy rear end
stu
Re: Coil Time
« Reply #3 on: November 27, 2004, 08:17:16 AM »
If there going with new gears he could keep the sammie rear diff, you get more ground clearence and the strenth is about the same, A friend of mine runs 5.83's in his with 4.89 low range with 33's and have never seen him break anything and yes he does rock crawl !   What coils did ya get and where abouts in Whittier do ya live?
  • 184
  • Rock the Sam
Re: Coil Time
« Reply #4 on: November 27, 2004, 05:03:00 PM »
I got coils from rocky road and i fabricated the control arms and bracketry. I live between beach blvd. and first street. sorta on the border of la habra and whittier. you from around here?
Re: Coil Time
« Reply #5 on: November 27, 2004, 06:27:32 PM »
YA, I was born in Whittier, grew up in quada lahabra, owned a home there for years off of walnut just so. of w. blvd, wife went to w. high and so did my grand parents(went there with tricky Dick)and so on, brother inlaw was the mayor of la Habra, I went to L.h. high, most the family moved only have four left real close to there,I make it down there once a year or so, would like to finish up my zuk a little more and make a run with justruns down there (yahoo club) or tds? I lived in big bear for four or five years befor moving to oregon.that place is hard on axels(b.b.)but worth it if you get the chance.
Offline shoyrtt
  • 161
Re: Coil Time
« Reply #6 on: November 29, 2004, 12:15:46 PM »
I have the RRO kit. I'm running the 6.1 t-case gears and 5.38 rp on stock axels. No problems yet :P If I had to do it all over again, RRO now has the kit available for Toyota axels.  ;)
Offline Natebert
  • 1098
Re: Coil Time
« Reply #7 on: November 29, 2004, 02:57:17 PM »
I'd go;
Stock kick for the rear end.
Custom kick rear center section with sammy knuckles for the front.
Trail Tough 'Double Tough' birfields.
Custom chromoly axles.
GRVIT
Re: Coil Time
« Reply #8 on: November 29, 2004, 03:41:20 PM »
hey Nate .....you dont know what an idea you gave me just now ..... ;D
Offline Speedracer7c
  • 2210
Re: Coil Time
« Reply #9 on: November 29, 2004, 04:09:35 PM »
I wish there was a sammi around here. I would be all over it in a heart beat.
Offline 1bigtracker
  • 3409
Re: Coil Time
« Reply #10 on: November 30, 2004, 03:22:37 AM »
want one?
stu
GRVIT
Re: Coil Time
« Reply #11 on: November 30, 2004, 04:54:02 AM »
I wonder how a Sammy with Sidekick axles (hybrid front-stock rear) would look like.....and if there would be any problems with the axle width and 33's  at full suspension(YJ leafs)  compression  ............
Offline Real_Red_Sammi
  • 43
  • Make it hurt!
Re: Coil Time
« Reply #12 on: December 01, 2004, 09:45:54 AM »
I got the 5.38's in my sammi, and the 35's every thing is fine. Perfect gear ratio for 35's. Stock axle's are holding up good, it also matters what tires you are running, I have dunlop mud rovers and they are considerably lighter in comparrison.
  Make It Hert!!!!!
"I do what I want"
LMS wasted my time
Offline 1bigtracker
  • 3409
Re: Coil Time
« Reply #13 on: December 02, 2004, 03:41:53 AM »
i think tracker axles are about 3 inchs wider than sammys.  and sammys have an offset rear diff so the tracker diff might have to be retubed and use stock sammy shafts.  the rear end should only cost about 100 bucks to build.
stu
« Last Edit: December 02, 2004, 03:42:10 AM by 1bigtracker »
GRVIT
Re: Coil Time
« Reply #14 on: December 02, 2004, 05:19:29 AM »
So you mean that Sidekick axles(F-Hyb,R-Stock) cant be used  in a Sammy ?   too wide heh ?
