Lift Idea
  • 1728 Views
Rodzilla
Lift Idea
« on: July 07, 2007, 05:15:21 PM »
Can't get reponse from Calmini for their Combo lift, guess they must have too much money. So I'm thinking of doing OME springs with OME Strutts and Shocks from Rocky Road and adding 1.5" Spring Spacers from Boondox and a 3" BodyLift from Boondox. Shoud give me close to the 6 inches of lift I want. I would have liked the A-arms from Calmini for better geometry but the above should work OK with Camber bolts to get a good alignment. Anyone have this combination and how do they like it...or any comments or thoughts about this would be appreciated. Thanks.
Offline museboy07
  • 641
Re: Lift Idea
« Reply #1 on: July 07, 2007, 05:32:33 PM »
ya that would put you right at six inches of lift...but you'll definately need front diff drop brakets and maybe a small driveshaft spacer...also to get full rear articulation you'll need to fab up a rear a arm spacer too
BigRedZuki
Re: Lift Idea
« Reply #2 on: July 08, 2007, 11:29:27 AM »
 its hard to explain.. how much longer are the ome struts than the ome springs in relation to the stock stuff, what i mean is how are you able to put spring spacers in without over extending the struts. and what would happen if you put the ome lift+2 inch strut and coil spacers on with a diff drop and rear a arm spacer and drive spacer.
Rodzilla
Re: Lift Idea
« Reply #3 on: July 08, 2007, 01:32:23 PM »
I found answers on another board where OME V6 Grand Vitara Springs are used with no spacers and about 3.5" of lift is acheived. He's logged thousands of miles and has had no CV probems.
