Track/Kick front hub
  • 2635 Views
Offline Rod
« on: July 12, 2007, 05:50:36 AM »
Does anyone know if a 93 front passenger side hub will fit a 96 Geo Tracker, 2-
door, 4x4?  Somehow my son managed to break off two of the ears that the wheel studs
connect to. There are now only 3 lugs holding the wheel on.  The local junkyard has a 93 Kick, but I don't know if the hubs changed over the years.
Rod
Rod
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: Track/Kick front hub
« Reply #1 on: July 12, 2007, 07:59:07 AM »
As long as you match 2-door with 2-door parts, it should all be the same.  4-doors had bigger brakes, but the guts were pretty much the same too, i believe.
1993 4-door Sidekick
4.24:1 t-case
Offline okezuki
  • 51
« Reply #2 on: July 12, 2007, 10:23:35 AM »
u can use it ,i believe. My buddy has a 97 and he swaped hubs and brakes from a 94 4 door after an accident.
« Last Edit: July 12, 2007, 10:27:15 AM by okezuki »
87,33`s,6-1 t-case,d.c.drive shafts,locked,m/l with cj`s,dt8000`s,& the will to BEAT THE SNOT OUT OF IT!
« Reply #3 on: July 12, 2007, 10:25:50 AM »
I wana see the ears, post a pic, LOL
Offline Rod
« Reply #4 on: July 12, 2007, 04:09:59 PM »
I found a hub out of a 95 4-door Kick today for $65.  It should be closer than the 93.  It looks the same, but I won’t know for sure until I try to install it.  The dealer (which is 20 miles from my house) wanted $128 and five working days to order it.  I’ll take some pics of the broken hub once I get it removed.
Rod
Rod
Offline Rod
« Reply #5 on: July 17, 2007, 06:18:32 PM »
I found a hub from a 95 4-door Kick at Fred's Used Auto Parts for $65
(that includes $15 for them to pull it). I watched this poor guy
that had just moved here from Minnesota sweat like crazy while he
attempted to pull it. It took him 2-hours. This guy had no
mechanical ability at all. He took off way too much stuff when all
he needed to do was remove one c-clip. They gave me my $15 money
back because it took so long. It took me about 2 hours to remove the
broken hub and install the new hub. The hub looked exactly the same
as the hub in the 96 2-door. I did notice that the front rotor was
vented on the 4-door model, but it didn't change the hub at all.
Rod
Rod
Offline mss94jx
  • 8
« Reply #6 on: July 18, 2007, 04:29:23 PM »
So how did he break off the ears? Musta hit something larger than a pebble.
Offline SnoFalls
  • 1358
« Reply #7 on: July 19, 2007, 12:46:28 AM »
I'd guess it got airborne (with a 1 wheel landing)
Offline Rod
« Reply #8 on: July 19, 2007, 11:05:01 PM »
He said he hit a speed hump and it made a funny sound : )
Rod
Rod
