How do M/T tires do when it is snowing?
  • 25 Replies
  • 7421 Views
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: How do M/T tires do when it is snowing?
« Reply #15 on: November 26, 2004, 12:08:56 AM »
Sounds great, thanks! ;D
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #16 on: November 29, 2004, 01:43:08 PM »
Can you be any more specific? Better yet any pics of how you had them siped? I now run radial swampers and if I'm not happy with their snow performance, I want to get them siped...
I just E-mailed you a photo. I dont have a way to upload it.
Mike
Offline Digger
  • 1991
« Reply #17 on: November 29, 2004, 03:31:02 PM »
I got it, thanks again! I'll chop it down a little and put it up here...
For all those that want to see it:
« Last Edit: November 29, 2004, 03:37:05 PM by Digger »
Offline Speedracer7c
  • 2210
« Reply #18 on: November 29, 2004, 04:02:40 PM »
Looks badass.
« Reply #19 on: November 30, 2004, 03:25:42 PM »
looks better than the job I got.
Offline Cwkick
  • 888
« Reply #20 on: December 01, 2004, 12:38:23 AM »
So, how exactly do they sipe tires.  I realize sipes are cuts in the tread blocks, but isn't it more than just taking a knife and cutting through the block?
Cwkick
Offline r3cc0s
  • 321
« Reply #21 on: December 01, 2004, 04:26:04 AM »
i think that's pretty much it
tires stores can have siping machines
essentially the same just using a saw and cutting at every interval you'd like like 3/8" for instance and how wide you want it
for myself i'd only sipe the center blocks and just run low tread
if you cut the shoulders, you could rip chunks out while crawling
Offline bzzr2
  • 1011
« Reply #22 on: October 03, 2006, 09:17:25 AM »
waking up an old thread here.....  anybody ever do this themselves at home?  i've called a couple tire shops in my area and they have no idea what i'm talking about...  at all..  any thoughts or experiences would be appreciated, thanks.  i dunno what kinda cutting tool will work best on my swampers.
09 taco reg cab short box 4x4
« Reply #23 on: October 03, 2006, 09:41:45 AM »
http://www.sipers.com/sipers/index_large.asp
You can use a heat knife to do it yourself, it just takes a while.  One of the other Zuki's in my club siped his swampers without a problem.
4x4 Wire Guide to Siping your own tires.
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #24 on: October 03, 2006, 12:09:30 PM »
you can sipe Swampers with a utility knife, no problem.
You can even cut grooves with a utiliy, it's hard to get them uniform, but you can do it.
As far as basic sipes,   a utility blade, cut down to the EXACT depth you want to sipe, works fine.
Offline cablesmurf
  • 123
  • Calgary Alberta Canada
« Reply #25 on: October 03, 2006, 12:47:50 PM »
I have run alot of tires o my Jeeps and such. IMHO, BFG AT TA/KO's are the best winter/all around tire made.  But since we're talkin mud tires...I like the Superswamper TSL SSR's. They are siped from the factory, and wear very well. Pricey, but woth the money. I'm running them on my Tracker right now.
Here's a review page:
http://www.off-road.com/suzuki/reviews/interco.htm
« Last Edit: October 03, 2006, 12:52:03 PM by cablesmurf »
Sold the Tracker, done with wheelin'...
Compliments of your friendly neighborhood cablesmurf
Check out my Powerlifting video...  http://whiteknight.scriptman
