How do M/T tires do when it is snowing?
  • 25 Replies
  • 7292 Views
Offline keith
  • 1176
« on: November 24, 2004, 12:10:53 AM »
Due to lack of siping my M/Ts tend to slide around in the rain when braking hard.  I'm wondering how they will do in light to moderate snow.  I think they will do great going through deep snow off road, but I'm not so sure about driving in traffic with it when it is snowing.
« Last Edit: November 24, 2004, 12:59:26 AM by keith »
Offline explosivo
  • 3157
Re: How do M/T tires do when it is snowing?
« Reply #1 on: November 24, 2004, 02:27:32 AM »
From what I've heard, MT's will do better in the deep stuff than normal winter tires, but will slip and slide around on the hard-packed stuff/ice due to the lack of siping :-/
omghi2.us[/url]
Offline r3cc0s
  • 321
« Reply #2 on: November 24, 2004, 02:36:46 AM »
living in wpg
I've talked to a few people
mudders like the dunlop, cooper stt, and even the mud terrain from what I heard are mediocre depending on the situation
if it's an ice/snowy area w/ large rocks
you'll slip all over the place, they will dig through deep snow (acctuality work better on deep snow) but the lack of siping will make you slip on the ice and their compounds are quite hard at anything below 27ish farenheight
however the goodyear mt/r appear to be soft enough to give decent traction in ice for a mt style
i've been told the good year mt/r is wicked if the center parts are siped like every 3/8th inch, but still aren't a solid winter performer
i've been told the bfg all terrains are great due to their design for winter and even the cooper m/s st's with stud'd
however i'll assume that light chains with a mud terrain should still be able to clear anything pretty well
jdraper
« Reply #3 on: November 24, 2004, 03:47:05 AM »
I have a set of 32 x 11.5-15 BFG M/T's on my Sammy, and it slips and slides around in the snow.  It's controllable, but the BFG A/T ko's are much better (I had them on my Explorer).
« Reply #4 on: November 24, 2004, 04:06:57 AM »
I run 33x12.5 BFG MTR's and last year they were all over the place on the icy snow.  Once I let some air out they came right in line.
That may not be an option though.
Offline DirtDevil
  • 317
  • Island4x4.com
« Reply #5 on: November 24, 2004, 05:47:10 AM »
trxus MT's are the only mt's id run in the snow, second choice would be mt/rs .. but the trxus mts have lots of factory siping and are a good compound for street driving or wheelin... if your doing alot of snow wheelin or driven, AT's are the way to go normally
Offline keith
  • 1176
« Reply #6 on: November 24, 2004, 05:50:46 AM »
If I have the center lugs siped by discount tire how do you think the tires will perform?
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #7 on: November 24, 2004, 08:28:28 AM »
I had a fried with Goodrich MT's that were siped and he claims they were the best snow tires he's ever had on is Jeep.
I have a new set of Goodrich All/T's (on a full size Chevy 2wd w/limited slip) that were siped.  We have about 1-2 inchs of snow on the ground now and they did great.  Was unable to get the tires to spin after the truck was rolling.
32 MTR's Warn 8000i
« Reply #8 on: November 24, 2004, 08:42:32 AM »
Have you run on the sipes long?  Sometimes it takes a little while for the tires to be able to flex properly.
I wouldn't want to sipe the outside lugs on my tires.  They get torn up to easily that way.
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #9 on: November 24, 2004, 09:19:06 AM »
I sipe tires at my job all the time. The best winter tire Ive ever had was a radial swamper with the center lugs siped. Even at max psi they are amazing. If you drop to 15psi they are even better. The MTRs and Bfg mt's are also a good tire to sipe the center on. The only real downside to siping is if you do a lot of burnouts they will chunk. However with Suzukis thats really not an issue! ::)
Mike
« Reply #10 on: November 24, 2004, 02:06:34 PM »
Mike
Says Who
;D
« Reply #11 on: November 24, 2004, 03:48:44 PM »
I can spin my swampers on the street  ;D I have run bfg mt's for about fourteen years, after ten years the tires start to get a little hard and will slip a little bit(all my rigs have streight axels) my cj7 I had them siped and added 200 lbs to the rear with a steel plate it worked great with 35's 410 gears and a 350 vortex I could go up a steep street in two wheel drive no prob. om my samurai I run nine psi in the winter on my tsl radials they work great,I just keep it under sixty.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #12 on: November 24, 2004, 04:01:24 PM »
I sipe tires at my job all the time. The best winter tire Ive ever had was a radial swamper with the center lugs siped. Even at max psi they are amazing. If you drop to 15psi they are even better...
Can you be any more specific? Better yet any pics of how you had them siped? I now run radial swampers and if I'm not happy with their snow performance, I want to get them siped...
« Reply #13 on: November 24, 2004, 04:46:46 PM »
I have radial swampers on mine and they come with some siping from the factory, if they are somewhat new they should be ok just let some air out.  the siping just looks like a streight knife cut going streight across the tire but not hitting the out side lugs about 3/8 of an inch deep.
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #14 on: November 25, 2004, 11:59:05 AM »
I will take a pic of my sisters radial swampers tomorrow with the digital. ;)
Mike
