QUESTION
  • 1548 Views
ehc530
QUESTION
« on: July 23, 2007, 09:19:41 PM »
hey. I have an 86 Sammy with a 91 Tracker engine swap.... if i bought an automatic tracker tranny would i be able to stick it in there in the samurai no problem???
Re: QUESTION
« Reply #1 on: July 24, 2007, 04:54:17 AM »
Unlikely, the Tracker engine is most probably mated to the original Samurai gearbox. The boxes are very different, the Track/Kick has the tcase mounted on the back of the box. The Sammy has a divorced tcase.
Offline j2custom
  • 197
  • Suzuki's rule!
Re: QUESTION
« Reply #2 on: July 24, 2007, 07:58:40 AM »
Yeah, it depends on how the swap was done.  If there is a 2wd manual sidekick trans with a jump shaft to the sami t-case then you could possibly put the sidekick 2wd auto in.  It is more likely (as earlier noted) that there is an adapter between the sidekick engine and sami trans.  If you do the swap prepare for a body lift or "massaging" the transmission hump to fit the trans.  Godd luck!
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
