hello, new member from Nevada w/ transfer case Question
  • 12 Replies
  • 3528 Views
4x4nvcowboy
« on: July 25, 2007, 04:08:56 PM »
so i have a 8"spoa lift for my 87 sami .. ???.i plan on daily driver with 30s for street 33s for play . what transfer case gearing should i use   4:1 or 6:1  , stock motor w/ 2" exhuast and header ,air intake ,stock axles (for now) . Whats going to do best to keep me |removethispart|@ 65 on the freeway and will still crawl over rock well....Thanks,  ;D   for your input in advance.....
heres another ? could it be possible to use a dana 300 t-case since its not married like a sami? (already have a d-300 t case)
« Last Edit: July 25, 2007, 07:16:27 PM by 4x4nvcowboy »
Re: hello, new member from Nevada w/ transfer case Question
« Reply #1 on: July 25, 2007, 07:49:24 PM »
ALL YOU GUYS ON HERE AND NO RESPONSE...you think you would welcome someone in ?  maybe share some knowledge .....guess not  ???
Simmer down Now ;) ;D
Just got home myself.
People will Chime in when they get here.
I personnelly drive drive a Kick but Sammies are also just as sweet.
Welcome aboard 4x4nvcowboy ;D ;D ;D ;D ;D
« Reply #2 on: July 25, 2007, 07:59:25 PM »
Welcome to the board.  :)
I say the 6.4:1 or higher if you want to be able to do 65.  Both the 6.4:1 and 8:1 gear sets have the same high range, so the only real difference is the low range.  Technically they are set to bring 35" tires back into stock gearing in high range, but you might want to run a little higher RPM then stock at those speeds.  Even then, don't expect to much on a hill.  A 5.8:1 should bring you back to stock gearing for a 33" tire, so that might be more then enough for you.
Do a search on the board on Transfer Case VS Gears and there are a couple of discussions on upgrading your gears instead of just going with lower transfer cases.  There are good arguments for both.
If you really want to run at highway speeds though, you might want to look at a 1.6L conversion to get that extra 30hp.
Offline j2custom
  • 197
  • Suzuki's rule!
« Reply #3 on: July 25, 2007, 08:01:08 PM »
You waited approximately 3 hours and 2 minutes and now your hating on the members?  Simmer down is right!
With the Sami t-case you have more gearing options than the dana 300 t-case.  Check the faqs for specs on sammi's, 31" tires and going 65 mph.  I am sure there are several guys who have done the math and the work to get it "dialed in".  I don't think the 4:1 will give you enough reduction in high range to keep it going 65, and I am not sure if the 6:1 has a "lower" (greater reduction) high range.  Check Calmini and Trail Tough for specs on their gear sets.  Someone will post the specs or links to it.
Be patient grasshopper and you will truly enjoy this form.  The members rock and there is a ton of info for all.  Welcome!! ;D
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #4 on: July 25, 2007, 08:41:43 PM »
Welcome, previous jeep/GM owner.
Did you just buy this thing, or what?
30" tires would look pretty ridiculous and may be somewhat unstable if you're running 8+ inches of lift.
You'd be better of regearing the thing and running the 33's all the time for stability's sake.
1993 4-door Sidekick
4.24:1 t-case
Offline ROSS
  • 1412
« Reply #5 on: July 25, 2007, 08:47:52 PM »
the gear sets from calmini give you both high and low reduction.
P.S.  most replies are answered within 24 hours. be patient grasshopper
Offline Gary_Hill
  • 288
« Reply #6 on: July 25, 2007, 11:28:07 PM »
Welcome Zukbrother and don't fret if response to your questions take more than a couple of hours. Most of these guys work or school all day.  When I first posted on this board a few years ago...I came on a little too strong myself and got silence....These are some of the best wheelers in the sport but they don't let there 4x4 expertise go to there heads. We don't talk sh_t and we don't disrespect anyone no matter how newby the question. Suzuki 4x4s are great rigs with unlimited potential.  Some of us have gone through all the other brands of 4x4s and are now DIEHARD ZUK FREAKS....we all have the EVIL SEED growing in our souls...
I also drive a sami, 8" SPOA, shackle reverse, on 33x11.50x15 True Tracs with a 1.3, Webber, header, 4:1 transfer. I dont drive 65 often because light Samis way up in the air with big tires are not all  that stable...but they are fun to drive  ;D  The stock axles will get a lot of stress with 33s ( and the birfields ) especially with power steering ( if you have it ) If you dont have power steering 33s will be hell in the big rocks.  Going up hill with 33s and stock 1.3 will be slow going...sometimes 2nd gear on long grades at elevation. I'll leave the gear questions to others more expert in that area. Welcome to the disease...Gary
sickmagna
« Reply #7 on: July 26, 2007, 01:21:20 AM »
hey man i got an 88 sami and am running 31x10.50's and it is bone stock cept for a k&n air filter. i just can't use 5th gear very much
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #8 on: July 26, 2007, 07:37:42 AM »
SEVEN RESPONSES AND NO ACKNOWLEDGMENT?...you think you'd appreciate feeling welcomed?  maybe say "thanks for the knowledge".....guess not  ???
XL-7 front coils
1.5" rear coil spacers
4x4nvcowboy
« Reply #9 on: July 26, 2007, 08:48:38 AM »
Thank you !
4x4nvcowboy
« Reply #10 on: July 26, 2007, 08:50:16 AM »
Thank all of you for your info ! I am greatful to have your input... :D
4x4nvcowboy
« Reply #11 on: July 26, 2007, 08:52:23 AM »
Thank you , and thanks for the advice ...feelin the love
4x4nvcowboy
« Reply #12 on: July 26, 2007, 08:53:44 AM »
SORRY, and thank you
