Has anyone done anything with the hole above the strut
  • 2277 Views
Offline RJkick
  • 634
« on: July 30, 2007, 07:53:03 PM »
Every time I hit a puddle water comes up and my battery gets corrosion.  Any ideas on stopping the water flow?  Battery box, rubber or sheet metal cover over the hole
any ideas would be good
Offline ToyYoda
  • 226
Re: Has anyone done anything with the hole above the strut
« Reply #1 on: July 30, 2007, 08:53:38 PM »
I have a X90 with a 3" body lift....plus. I got some thin sheet metal & cut out a plate to seal the exposed area where the strut was lowered. I then hammered the area flat & drilled two holes & used one of the stock holes that was there. The three bolts (total) work well & look clean to hold down the sheet metal sealing the area.. If & when you get rid of the stock air box & install a custom (K&N type) air filter the hole you talk of is a bigger problem. If you want I'll send a pic. of what it looks like under my hood. Hope this helps.
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #2 on: July 30, 2007, 10:01:22 PM »
i screwed in a piece of rubber from underneath with some sheet metal screws and speed clips on the back side of the rubber.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline Deathrunner
  • 33
  • Don't have a zuk, but a man can dream...right?
« Reply #3 on: August 06, 2007, 09:18:15 AM »
Here's a pic of what Toy Yoda is talking about:
« Last Edit: August 06, 2007, 09:19:58 AM by Deathrunner »
T.O.Y.O.T.A.
Take Off Yer Oversized Tires A$$hole
Offline RJkick
  • 634
« Reply #4 on: August 06, 2007, 12:11:38 PM »
WOW that looks excellent
