time for front brakes any sugestions?
  • 1950 Views
Offline JoeCool
  • 164
  • Carpe Noctum!
    • cardomain
« on: August 01, 2007, 09:52:58 AM »
So it's time again for new brakes on my 90 2dr kick any sugestions on what to buy that's better than the Autozone speacial? I do a lot of mountain resort driving so heat resistance is a good thing, is there any way to over size rotors and callipers while I'm at it? Also looking to move to rear discs in the future what advice can you point out for that. (yes I've seen the spidertraxx units)  Does anybody know if the calliper mounting holes are the same for the larger vented rotor combo from later units are the same as mine or would a change in knuckles be nessacery?   NMc
5psi turbo '90 2dr 5spd 8v Tracker, Lt235s, 1" spacers, Rocker Rails, Warn Hubs, Custom half door,--GONE!
New, Sammi Tintop
Offline stock93tracker
  • 309
Re: time for front brakes any sugestions?
« Reply #1 on: August 01, 2007, 10:27:47 AM »
4 door rotors and calipers fit on a 2 door..  Ive swapped mine and noticed a difference in the braking
93 Geo Tracker
-2" Lift
Offline whateverworks
  • 110
« Reply #2 on: August 01, 2007, 02:53:40 PM »
94 and earlier 4dr calipers will swap over to a 2dr kick... Major difference in the mounting of the front calipers in 95 and up.
Kelly
« Reply #3 on: August 02, 2007, 05:10:32 AM »
I've got '92 4dr brakes front and back in my SWB. I had rear discs for a while but getting the parking brake to work was a PITA so I went to the bigger LWB drums.
« Reply #4 on: August 03, 2007, 11:00:16 AM »
Good prices on drilled and/or slotted rotors with Zinc coating on Ebay.  Bling-bling. ;D
Offline j2custom
  • 197
  • Suzuki's rule!
« Reply #5 on: August 03, 2007, 12:46:37 PM »
Has anyone run these?  How do they work and hold up?  Thanks ;D
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
