vw deisel 1.6 swap, need some advice
  • 1808 Views
speedball1981
« on: August 02, 2007, 10:13:32 PM »
I found a vw deisel, 1.6 non turbo in my area for $100, before i buy it, i was wondering what other costs I might encounter if i choose to buy it,   and if the 1.6 is even woth it, and maybe I should wait for a 1.9turbo,  etc.  I havn't looked into it to much yet,
thanks.
Offline Uncivilized
  • 1469
    • Car Domain
Re: vw deisel 1.6 swap, need some advice
« Reply #1 on: August 03, 2007, 03:46:27 AM »
If it were me, I wouldn't swap to a diesel unless it was turbo diesel
Offline Jeff@TireBalls
  • 559
« Reply #2 on: August 03, 2007, 05:08:01 AM »
Cost will depend on which car it came out of and which accessories your getting with it.
2000 Grand Vitara Limited, 2" lift, 225/75-16 BFG KO's, 5.12 gears, Safari snorkel, roof rack.
1987 Samurai LWB, VW 1.9 Turbo Diesel.
Offline whateverworks
  • 110
« Reply #3 on: August 03, 2007, 06:23:08 AM »
Here is alot of good info on diesel swaps for Zuks...
http://www.acmeadapters.com/store_engine.php
Kelly
Offline mverley
  • 652
  • 20
  • SPACE JUNK
« Reply #4 on: August 03, 2007, 08:39:17 AM »
I ran two different 1.6 NA's in my sami (an old tired one and a freshly rebuilt one), then built a custom TE04H turbo setup.  Then I added propane injection.  Here's my advice:
The big advantage of swapping to the 1.6NA is fuel mileage; I got in the 30MPG range on the street with 33" SSR's.  Power is a litle disappointing...feels kinda like a stock 1.3.  Good torque for off-road though.
The swap is fairly easy if you buy a kit from Acme Adapters www.acmeadapters.com.  I just used the bellhousing adapter and flywheel from them and built the rest...took about 18 hours total.  I got my first 1.6 for free and was into the swap about $600.  I sold my built (cam, wiseco pistons, ported/polished, weber) 1.3 for $500.
The time it took to build the manifolds for the turbo was huge...if you value your time at about $.10/hr it might be worth it, but I wouldn't do the same thing again if I had to.
The propane injection with the turbo was an easy project, good for about 15-20% more power and a few extra MPG (IDI engines don't benefit from propane like DI engines do).
All finished, I was probably close to 100HP with my little 1.6, but I had the pump turned way up and couldn't keep my foot on the floor for long without exceeding EGT limits.
Here's what I would do:  If you're looking for killer fuel mileage and don't care about power, swap in the 1.6NA.  If you want more power than your 1.3 has, find a 1.9TD (I searched for months and only found them for $1500+).  If you're not set on running a diesel, I would say to go for a different swap...the 16V swap is fairly easy and common, and nets you plenty of power.
My rig is a fusion of Jazz and Funk; I call it JUNK
