Which camber bolts? Double or single offset?
  • 4865 Views
« on: August 06, 2007, 10:21:37 AM »
Which ones?  Spicer makes 2 that apply to the Kickers...
SPICER Part # 6161035  {Professional Grade Use Magnetic Camber Gauge If Necessary; 4 Wheel Alignment}
Front Susp.; Minus 1-3/4 Degree To Plus 1-3/4 Degree; 12mm Bolts; Single Offset
or
SPICER Part # 6161048  {Professional Grade}
Front Susp.; Up To Plus/Minus 1-1/4 Degree; 12mm Bolts; Double Offset
Need to order a set and don't know which ones.
Offline whateverworks
  • 110
Re: Which camber bolts? Double or single offset?
« Reply #1 on: August 06, 2007, 12:17:38 PM »
80-84 VW Jetta camber bolts will work just fine. Can be found at any parts store and have up to 3degrees offset.
Kelly
