Weber tuning
  • 2328 Views
Mudjockey#1
Weber tuning
« on: August 08, 2007, 05:36:43 PM »
I have a 32/36 with manual choke,  it seems to be running rich, and  will load up bad between 3000 and 4000 rpms |removethispart|@ 4000 it runs down the road |removethispart|@55 top speed!!!  any input would be great.   Still has stock fuel pump and we are wondering if the power valve may be bad or plugged?????
copperfever
Re: Weber tuning
« Reply #1 on: August 09, 2007, 05:56:40 PM »
Are you using a fuel pressure regulator? Webers usually won't run right with more than 3 psi of pressure...
Also, if your carb is used or came from another engine, you may need to re-jet it.
Mudjockey#1
Re: Weber tuning
« Reply #2 on: August 10, 2007, 07:26:20 AM »
Thanks for the tips,  and no I don't have a regulator on it yet.  And yeah this carb came off a 20R Toyota and we have wondered about jetting it but not sure where it should be?  I leaned it down again a couple days ago and it seemed to help, when pulling a hill you have to barely feed it pedal or it boggs! :(
Re: Weber tuning
« Reply #3 on: August 10, 2007, 10:24:25 AM »
You will almost certainly have to rejet. I thought that the Weber manual was online somewhere but a quick search only brings up the one for the later kit with the 32DGR carb. Link is below FWIW. I'm pretty certain that you don't need to change the pump for the downdraught carbs.
http://www.suzukitech.org/pdf/sjweber.pdf
Offline daddyizzle
  • 728
  • Colorado is still my home!!
Re: Weber tuning
« Reply #4 on: August 10, 2007, 04:12:17 PM »
Not sure on rejetting (Probably better rejet) but you better start off with the regulator first. Otherwise rejetting won't solve the problem. You're most certainly flooding it. I paid $45.00 + tax roughtly for a holly brand at Autozone. I mounted it above the right side fender well since there was a threaded hole right there.
-Adam
Mudjockey#1
Re: Weber tuning
« Reply #5 on: August 10, 2007, 06:02:55 PM »
Heading to Autozone tonight!!! ;D  Thanks and I let you know how it does ;D
