Holy Melting Fuse, Batman....
  • 18 Replies
  • 5781 Views
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: Holy Melting Fuse, Batman....
« Reply #15 on: August 14, 2007, 04:05:55 PM »
Since we're on the subject of AC fuses, is there a fuse that controls just the electric AC fan?  Or is it controlled by the same fuse as pictured above.  My compressor kicks on, but fan won't work.
Attached pdf files.
XL-7 front coils
1.5" rear coil spacers
Offline Gary_Hill
  • 288
« Reply #16 on: August 14, 2007, 08:59:38 PM »
Crickey...I can,t speak for the older Kicks, cause mines 2nd gen, but when I had the same trouble ( compressor running but no fan ) the problem was solved when I giggled the little relay box located behind the passenger speaker pannel. It was up in there and hard to get at but only took a giggle to fix.
Offline MKOLSEN22
  • 217
  • Come on 32's
« Reply #17 on: August 17, 2007, 11:37:20 AM »
Did you tickle it with a feather to get it to giggle?
Offline MKOLSEN22
  • 217
  • Come on 32's
« Reply #18 on: August 17, 2007, 11:56:14 AM »
showed one 15 amp fuse that took a direct short across the battery and only melted the plastic around the fuse.
You don't really believe this, do you?
My first post was just a heads up or FYI, but I don't think that saving ten cents on a fuse would be worth having a potential melt down.
Send me your e-mail message and I will forward the message to you complete with pictures.
