exhaust fumes
  • 2477 Views
Offline bus_driver
  • 479
  • the voices tell me different things
exhaust fumes
« on: August 14, 2007, 12:42:19 AM »
ok i have exhaust fumes in my truck when ever i have the soft top on. is the stock outlet on the driver side mud flap the only safe out let? i do have some rust holes they are not big but they are at the back.
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline Jimiweld
  • 234
    • www.fullfusion.ca
Re: exhaust fumes
« Reply #1 on: August 14, 2007, 04:03:33 AM »
Hey Bus-Driver
  I have the cherry bomb on mine as well and just put a turn down on it under the tracker instead of running it right out the back. I kept everything above the frame rails so no problems off roading and no fumes with the top off. I have fixed my holes in rear though. When we go offroading you can check it out, if you want to try it on yours we can weld a turn down on at my shop.
Jim
Offline bus_driver
  • 479
Re: exhaust fumes
« Reply #2 on: August 14, 2007, 08:23:02 AM »
hey jim where did your exhaust stop at my turn down will be right in front of the axle.
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline Jimiweld
  • 234
    • www.fullfusion.ca
Re: exhaust fumes
« Reply #3 on: August 14, 2007, 11:52:58 AM »
Yep, that's where mine is too, I just welded a turn down on the end of the cherry bomb and so far so good, not sure if it's legal like that. I think for a pick up technically as long as it goes past the cab and has a turn down it's legal, not sure about on our trucks, but no smell of exhuast in the cab even with the top off.
  How bad are your floors for holes?
Jim
Offline BFM
  • 49
  • 4x4 oh yeah!
Re: exhaust fumes
« Reply #4 on: August 14, 2007, 12:36:08 PM »
If you turn the exhaust manifold upside down and remount with a big hole through the hood you can get rid of exhaust fumes under your truck. >:D
'93 Geo Tracker, 3" suspension lift, 31" tires, dome light replaced with cadilac LED brake light bar, tinted, towed home once, dropped off of tow truck once, top speed attempted/achieved 135 km/h = shaking baby syndrome
Offline Jimiweld
  • 234
    • www.fullfusion.ca
Re: exhaust fumes
« Reply #5 on: August 14, 2007, 05:25:20 PM »
That would like damn cool too, run the pipe right over the windshield, like something out of Mad Max
 ;D
g-man
Re: exhaust fumes
« Reply #6 on: August 14, 2007, 06:09:22 PM »
LOL  Demo derby tech at its best!!
Offline bus_driver
  • 479
Re: exhaust fumes
« Reply #7 on: August 15, 2007, 12:13:57 AM »
swiss cheese kick is the new name
92 2dr soft top
235/75/15
2 inch lift
custom mud
