monroe sensa trac shocks??
  • 15 Replies
  • 5223 Views
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« on: August 16, 2007, 01:34:53 PM »
anyone else have any issues with these things?? im on my 2nd set in less than 6 months of driving the thing and their already leaking.....these are the crown vic shocks....part #5961
Offline muskegtracker
  • 273
  • 10
  • Mr T
Re: monroe sensa trac shocks??
« Reply #1 on: August 16, 2007, 02:31:22 PM »
Did you lower the bump stops when you installed the shocks?  The Shocks will bottom out on full compression damaging the internals and seals.  Causing leaks.  Does this make sense?
If you put a longer shock in the same range of bump as a shorter one, the shock will bottom out  before the bump stop will, because the shock body is longer.  This is especially noticable on extreme flex, when one side will be completely compressed.
91 Chevy Tracker
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #2 on: August 16, 2007, 03:36:24 PM »
yup, i extended the bumpstops 2" to compensate for my 2" spacers
erik the red
« Reply #3 on: August 16, 2007, 04:02:53 PM »
I hate to say it, but I have heard from several people that monroe sensa trac shocks are flawed in their design. I personally haven't run them in any rigs of mine, but from the boards there have been a few guys saying how crappy they were. I don't mean to be a downer, sorry.
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #4 on: August 16, 2007, 05:45:02 PM »
I run the plain blue monroe shocks and have had no problems at all on any of my vehicles
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline RHodge
  • 523
« Reply #5 on: August 16, 2007, 07:53:09 PM »
I'v never liked monroe shocks or struts ,   And I sell the darn things
Kyb or bilstein are nice
Offline olija
  • 770
    • Check out my cardomain
« Reply #6 on: August 16, 2007, 10:59:24 PM »
I have the Gas-Matic shocks with a 1.5" lift and I think they are leaking a bit, but I have bottomed them out pretty hard and I never lengthened the bumpstops.
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #7 on: August 17, 2007, 07:49:12 AM »
thank goodness for the lifetime warranty on 'em....they arent too bad to change.....ill just have to keep an eye on em, and change them for free when they start leakin
Offline RHodge
  • 523
« Reply #8 on: August 17, 2007, 04:53:09 PM »
yepp  ;)
Offline bus_driver
  • 479
  • the voices tell me different things
« Reply #9 on: August 18, 2007, 12:15:38 AM »
canadian tire when ordering monroe shocks always order 5 at a time since they are defective from the factory. this was told to me by canadian tire but since they have the warranty they don't care that they know the shocks are crap. i like the idea of a multi valve system.
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #10 on: August 18, 2007, 01:40:36 PM »
me too....just by workin the shock by hand you can actually feel them, its really weird....is there any benefit to this??
Offline bus_driver
  • 479
« Reply #11 on: August 18, 2007, 01:53:06 PM »
what the auto adjusting valve is suppose to do is if you go over little bumps then it is softly valved to soak them up and when you hit a real big bump the valve adjust to a firmer setting and controlls the wheel hop. dad has them on his 2500 gmc converted van and he said they are ok but it takes a few bumps b4 they adjust. rancho rsx series also has the auto valve. there are a few different manufacturers that use it. bilstein are they best in my opinion but that is the money part aswell.
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #12 on: August 19, 2007, 08:28:56 AM »
ya, i didnt wanna fork out that kinda money on my beater vehicle, and i used to work at an autoparts store that sold them, so i got a discount....and they were right on the shelf, so i didnt have to order them like i did the bilsteins
Offline bus_driver
  • 479
« Reply #13 on: August 20, 2007, 12:22:47 AM »
discounted and available that is how i like them parts
92 2dr soft top
235/75/15
2 inch lift
custom mud
« Reply #14 on: August 20, 2007, 04:51:02 AM »
Did you check that that was enough? The shocks may have much longer bodies than the stock shocks. You should pull the springs and then raise the rear axle to see if the shocks compress fully before the bumpstops are reached. I guess you could measure it but if you're changing the shocks anyway its no biggy to whip the springs out.
