ignition key
  • 1998 Views
rugbytown
ignition key
« on: August 17, 2007, 11:30:12 PM »
I have just bought a 94 tracker and the key is stuck in the ignition. Any ideas how I can get it out?
Offline SKAsammy
  • 79
  • 1991 samurai
Re: ignition key
« Reply #1 on: August 18, 2007, 03:24:59 AM »
cutting torch ;D
1991 SAMURAI
6"spoa
2" body  lift
8000 lb winch
30/9.5/15 BFG all terrains roll on bedliner in and out homemade bumper 1996 Silv. 4" lift 35's many mods
ace69247no13
Re: ignition key
« Reply #2 on: August 18, 2007, 05:39:54 AM »
so the key is stuck in the ignition huh well that may be a good thing the best easiest and least destructive to get the lock cylinder out of most ignitions is with the key in it. i would just suggest changing the cylinder out completly
« Last Edit: August 18, 2007, 05:54:19 AM by ace69247no13 »
Re: ignition key
« Reply #3 on: August 18, 2007, 07:55:59 AM »
Is the steering lock engaged? Try turning the steering wheel both ways to see if the key will turn another click. If not try some WD40 or similar.
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
Re: ignition key
« Reply #4 on: August 18, 2007, 09:28:57 AM »
If it is an automatic it could be that the park lockout is not ingaging properly. Dave
Student of Now Master of Then
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: ignition key
« Reply #5 on: August 19, 2007, 07:21:32 AM »
Rhinoman has the good advice assuming the key is not broken off in the lock...
often times on older vehicles the ignition switch wears to the point where you have to apply slight turning pressure to the steering wheel or to the shifter lever (if it is automatic) in order to get the key to move.
This feature is in place on automatic transmission vehicles to provide the same fuction as the clutch ignition switch does in order to prevent the operator from trying to start the vehicle while it is in gear.
Hope that this helps!
Ack
