Will my tires rub?
  • 1983 Views
Offline museboy07
  • 641
Will my tires rub?
« on: August 19, 2007, 08:47:50 PM »
I might be gettin some wheels that are 15x8 with 4in backspacing.  Is that much BS to run 31s on? Will they rub on the frame?
Offline bus_driver
  • 479
  • the voices tell me different things
Re: Will my tires rub?
« Reply #1 on: August 20, 2007, 12:40:28 AM »
yes we need from lip to mounting surface 3 inch to not rub..
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline museboy07
  • 641
« Reply #2 on: August 20, 2007, 04:18:57 AM »
what about 3.75" BS...any better?
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #3 on: August 20, 2007, 05:46:59 AM »
Mine are either 3.75 or 3.5... I don't remember, but mine don't rub, I'll check at lunch to see exactly how close they are. You may have a problem rubbing the wall of the inner fenders in the rear when your suspension is flexed, but rubbing that at slow speeds(momentarily) isn't going to destroy anything  ::)
I wouldn't worry too much about rubbing the frame, you can adjust your steering stops to fix that.
Another thing too - what brand/series tire are you going to use? Most 31" tires don't measure a full 31". My BFG AT's actual measurement is 30.7" brand new, my used ones measure about 30.4"
