trackick front diff
  • 2261 Views
Offline sector
trackick front diff
« on: November 25, 2004, 03:34:27 AM »
Hi !
Newb here, and I have a question concerning the front diff.
My friend has a 89 sidekick 2 doors and he broke his front diff. I can have a complete mecanic from a 91 4 door sidekick AUTO, will the 4 door diff fit or is it different?
And what about the ratio, I guess its the same?
Thanks a lot!
Offline hcgalvin
  • 1695
    • Granite Path
Re: trackick front diff
« Reply #1 on: November 25, 2004, 03:56:34 AM »
Was the 89 2 door an auto or a manual?
Heather Galvin
Offline sector
« Reply #2 on: November 25, 2004, 04:07:07 AM »
The 89 is a manual, that's mainly why I was wondering if it is a direct fit ! ???
Offline Biggerhammer
« Reply #3 on: November 25, 2004, 04:20:22 AM »
The auto and manual diff's are different. 4.62 in the auto's and 5.12's in the manual.
Offline Speedracer7c
  • 2210
« Reply #4 on: November 25, 2004, 04:38:32 AM »
The diff housings are the same, just the ratio's are different.
Offline 1bigtracker
  • 3409
« Reply #5 on: November 25, 2004, 05:09:41 AM »
ditto, if the housing is broke, not the ring and pinion, they you can switch the gears from the broken one to the good one.;  but if you can't set the backlash on the gears leat a pro swap the gears.
stu
Offline sector
« Reply #6 on: November 25, 2004, 07:24:39 AM »
He broke the lower diff mount ( it completely ripped off ) AND I "guess" the pinion gears.
His 4H/L still works, and his front wheels turns, but only if he goes straight.
The minute he turns, you hear the gears cracking and the truck stops, so I guess there's nothing worth keeping :(
Offline 1bigtracker
  • 3409
« Reply #7 on: November 25, 2004, 07:50:08 AM »
sounds more like he broke the spider gears inside the carrer.  but if you going to just throw all that junk away then could you send it to me insted? ;D
stu
  ÂÂÂÂÂÂÂ
