Bad Shimmy from the front end at 60? ......... Wheel bearing?
  • 11 Replies
  • 4076 Views
seamaster
At go it shimmies
Rotor?
Wheel bearings?
any other suggestions on what to look for?
Offline SnoFalls
  • 1358
Re: Bad Shimmy from the front end at 60? ......... Wheel bearing?
« Reply #1 on: August 24, 2007, 11:01:40 AM »
steering column joint (aka rag joint)
tierods
steering box (unlikely, but they can wear)
seamaster
« Reply #2 on: August 24, 2007, 11:03:06 AM »
Thanks
 ;D
« Reply #3 on: August 24, 2007, 11:36:59 AM »
Are we talking Sammy or Tracker? Sammy could be Kingpins or steering stabiliser.
Offline reb
  • 195
  • Victim of CRS--Can't Remember Anything.
« Reply #4 on: August 24, 2007, 12:01:57 PM »
Tires out of round or unbalanced have caused vibrations for me, usually around 60 mph.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #5 on: August 24, 2007, 03:23:27 PM »
Yup, plenty of times for me... and actually right now I have one out of balance ;) I've lost weights a couple times wheeling, got a re-balance and all was good.
Offline SnoFalls
  • 1358
« Reply #6 on: August 24, 2007, 04:26:07 PM »
throw a golf ball or 2 into the tire and it'll help too :)
« Reply #7 on: August 24, 2007, 08:48:07 PM »
only over 27 mph LOL.
Offline JoeCool
  • 164
  • Carpe Noctum!
    • cardomain
« Reply #8 on: August 25, 2007, 10:34:52 PM »
Could Also be caster set too low. Too much caster and and it's hard to turn at slow speeds too little and it will shimmy or wonder above a given speed. Given that our zuks where mostly designed to run at 55ish they don't have a lot to start with and a little set back from bumping the front wheels can alter it further back. Hunting for zebras I know but it's true. Wider tires/rims on stock backspacing will increase rolling resistance outward of the designed center of load making it toe possitive at speed.                             NMc
Too much education not enough practicality.
5psi turbo '90 2dr 5spd 8v Tracker, Lt235s, 1" spacers, Rocker Rails, Warn Hubs, Custom half door,--GONE!
New, Sammi Tintop
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #9 on: August 26, 2007, 07:44:03 PM »
Just for grins, make sure your lug nuts are tight.  Like, now.
XL-7 front coils
1.5" rear coil spacers
Offline 87Sam87
  • 63
  • '87 Samurai JA and '86 Samurai JX
« Reply #10 on: August 27, 2007, 10:09:40 PM »
   On my Sammy I had a bad steering damper and the the front end would shimmy like crazy between 50-60 mph.
seamaster
« Reply #11 on: August 28, 2007, 06:18:02 AM »
ROFLMAO
Thanks for the Lug nut suggestion! cute and the golf balls ( Im sure there is a story behind that )
But yes thanks for the (crash course) i use that in fear.... in sami front end issues.
It looks like in investigation too much mud threw it terribly out of balance!
