torque specs flywheel 1988 sammy ?
  • 6276 Views
bryans 86
« on: August 28, 2007, 08:15:33 AM »
i really need to buy the book but does anybody know the torque specs for a 1988 sammy for the fly wheel to the crank ?
Offline wheresmyhat
  • 244
  • 16v here I come baby!!!
Re: torque specs flywheel 1988 sammy ?
« Reply #1 on: August 28, 2007, 11:35:46 AM »
58
but just incase you find something else to do............
torque specs
Engine____________________________Ft-lbs
Spark Plugs............................................. ......_21
Camshaft cover bolts......................................_3 to 3.5
Intake/exhaust manifold nuts/bolts...................._13.5 to 20
Camshaft sprocket bolt..................................._41 to 46
Cylinder head bolts
____8 valve engine........................................_46 to 50
___16 valve engine
_______Step 1.............................................._25
_______Step 2.............................................._40
_______Step 3.............................................._48 to 50
Crankshaft pulley bolts...................................._7.5 to 9
Crankshaft pulley center bolt
____8 valve engine........................................._52
___16 valve engine........................................._76 to 83
Oil pump gear plate bolts.................................._7 to 8.5
Oil pump-to-block bolts...................................._7 to 8.5
Oil pan bolts/nuts..........................................._7 to 8.5
Flywheel/driveplate bolts.................................._58
Timing belt cover............................................_ 7 to 8.5
Rear main seal housing bolts............................._8
Rocker arm shaft retaining screws......................_7 to 8.5
Timing belt tensioner bolt................................._17.5 to 21.5
Timing belt tensioner nut.................................._7 to 8.5
Engine mounting center member bolt.................._43
Distributor gear case bolts................................_6 to 7.2
Main bearing cap bolts....................................._36.5 to 41
Connecting rod cap nuts.................................._24 to 26.5
Manual Transmission________________Ft-lbs
Oil fill and drain plugs......................................._20
Transmission-to-engine bolts/nuts
____Samurai....................................... ..........._16 to 25
____Sidekick/Tracker......................................._51 to 72
Input shaft bearing retainer bolts......................._14 to 20
Shift lever retainer bolts (Samurai)....................._30 to 60 in-lbs
Auto Transmission__________________Ft-lbs
Transmission-to-engine bolts and nuts................_62
Torque converter-to-driveplate bolt..................._62
Oil pan bolts............................................. ....._9
Transfer Case______________________Ft-lbs
Transfer case-to-transmission nuts....................._20
Shift lever case center bolt..............................._60 in-lbs
Shift lever case bolts
____Sidekick...................................... ............_144 in-lbs
____Tracker....................................... ............_20
Clutch and Drivetrain__________________Ft-lbs
Pressure plate-to-flywheel bolts.............................._14 to 20
Driveshaft nuts and bolts
____Samurai....................................... ................._17 to 22
____Sidekick and Tracker......................................._36 to 43
Freewheeling hub
____Manual locking
_______Hub body bolts........................................._15 to 22
_______Hub cover bolts........................................_72 to 109 in-lbs
____Automatic locking
_______Hub body bolts........................................._15 to 21
Kingpin bolts (Samurai)......................................... ._15 to 22
Front wheel bearing nut (Samurai)..........................._96 to 132 in-lbs
Front wheel bearing lock nut (Samurai)....................._43 to 65
Driveaxle flange bolt and nut (Sidekick/Tracker)........._29 to 43
Front axle housing mounting bolts (Sidekick/Tracker)
____Left side.............................................. ........._37
____Right side.............................................. ........_37
____Rear.......................................... ..................._37
Front wheel bearing locknut (Sidekick/Tracker)
____1992 and earlier (all models)............................._89 to 148
____1993 and later
_______Tracker.................................... ..............._155
_______Sidekick................................... ................_180
Differential carrier bolts
____Samurai....................................... ................._20
____Sidekick/Tracker........................................... .._41
Differential drain plugs
____Front......................................... ..................._32
____Rear.......................................... ..................._36
Brake backing plate bolts/nuts................................._14 to 20
Wheel lug nuts.............................................. ........
Suspension_______________________________Ft-lbs
Front Suspension_
Samurai
____Leaf spring U-bolt nuts..........................................._44 to 58
____Leaf spring shackle pin nut......................................_22 to 40
____Leaf spring eye-to-frame bolt.................................._33 to 50
____Front strut/shock absorber upper mounting nuts.........._14 to 22
____Front strut/shock absorber-to-steering knuckle nuts...._58 to 75
____Lower control arm
_______Front nut............................................... .........._50 to 75
_______Rear nut............................................... ..........._65 to 100
____Balljoint stud nut............................................... ....._32 to 50
____Balljoint-to-lower arm nuts......................................._50 to 75
____Spindle-to-steering knuckle bolts..............................._29 to 43
Rear Suspension_
Samurai
____Leaf spring U-bolt nuts............................................_4 4 to 58
____Leaf spring shackle pin nut......................................._22 to 40
____Leaf spring eye-to-frame bolt..................................._33 to 50
____Rear balljoint boss bolts..........................................._2 9 to 43
____Upper arm bolts............................................. ........._58 to 72
____Proportioning stay bolts..........................................._1 7
____Trailing rod nuts.............................................. ......._58 to 72
Steering__________________________Ft-lbs
Steering wheel nut........................................_18 to 28
Steering gear mounting bolts..........................._51 to 65
Intermediate shaft pinch bolt.........................._14 to 22
Pitman arm-to-steering gear nut......................_101 to 129
Tie-rod end ballstud nut................................._22 to 40
Steering shaft rubber joint bolts......................._11 to 18
Pitman arm nut............................................._1 01 to 129
Drag link nut (Samurai)..................................._22 to 50
Center link nut (Sidekick/Tracker)....................._22 to 50
Idler arm nut (Sidekick/Tracker)......................._50 to 72
Steering knuckle seal retainer bolts..................._96 in-lbs
Fuel and Exhaust___________________Ft-lbs
Fuel pump-to-cylinder head nuts........................_7 to 11.5
Carb/throttle body mounting nuts/bolts..............._13.5 to 20
O2 sensor............................................ .........._40
Cooling____________________________Ft-lbs
Fan clutch-to-water pump nuts........................._6 to 8.5
Thermostat housing bolts................................._7 to 12
Water pump-to-block bolts..............................._7 to 9
Brakes____________________________Ft-lbs
Brake bleeder screw........................................_8
Brake hose-to-caliper inlet fitting bolt................_14 to 18
Caliper carrier bolts........................................._51 to 72
Caliper mounting bolts....................................._18 to 20
Master cylinder mounting nuts..........................._7 to 12
Power brake booster mounting nuts...................._7 to 12
Wheel cylinder mounting bolts..........................._6 to 9
Body____________________________Ft-lbs
Door_
____Glass stud nut..........................................._4
____Hinge bolt.............................................. ..._26
____Handle nut............................................... ._4
____Latch screw............................................. ._7
Front door vent window screw............................_1
Rear door stationary glass channel frame screw....._1
Hood hinge bolt.............................................. .._23
Lift gate
____Hinge bolt.............................................. ..._7
____Striker screw............................................. _22
Front seat frame-to-floor nut.............................._18
Rear seat-to-seat back cushion hinge bolt............._33
Safety belt anchor bolt......................................_36
originally posted by rotozuk from PBB
« Last Edit: August 28, 2007, 11:37:46 AM by wheresmyhat »
86 sami 87 motor and a few other years in there probably, dana 44 rear,36"tsl. I once had splitfire spark plugs.
« Reply #2 on: August 29, 2007, 05:04:51 AM »
Flywheel bolts must have Loctite or similar thread locking liquid used on them. You will get false readings if you don't clean the old Loctite off first.
Offline daddyizzle
  • 728
  • Colorado is still my home!!
« Reply #3 on: August 29, 2007, 04:59:06 PM »
I just forwarded this to myself so I remember to check mine. I had mine off and I don't remember using locktite. I have it torqued down pretty tight but I better throw some locktite on because I sure as hell don't want to find out what happens if it comes loose. Thanks for the reminder.
-Adam
« Reply #4 on: August 30, 2007, 04:59:47 AM »
-Adam
It falls off   :o. One guy over here who races an SJ had two or three flywheels come loose, now he has extra dowels fitted. When I removed the box on my SJ there was one bolt missing, the others seemed tight enough but it made me wonder.
