Could someone give me some advice on how to fix my timining situation?
  • 2281 Views
Badtaste
I can't figure which is the best way to fix the timing, on my 87' Samurai. My engine runs it just spits and pop, so I'm sure the timing is off. I replaced the belt and adjusted the timing and I'm still having the same problem. I don't know if I need to replace my crank shaft or if there is something else wrong with it. I tried finding an Adj. cam sprocket but theyre not made anymore. Any advice would be much appreciated.
Re: Could someone give me some advice on how to fix my timining situation?
« Reply #1 on: August 29, 2007, 03:20:08 PM »
My guesses.....
1) when you replaced the belt, you didn't get the cam and crank phased correctly.
2) the timing is not adjusted to spec...should be 10* BTDC.
3) the crank pulley is loose and/or the key or key slot is worn.
PhnxCaller
« Reply #2 on: August 29, 2007, 06:59:02 PM »
I was having the same problem on my 86, turned out to be a worn key slot on the end of my crank. Yours could be a worn slot on the pulley, which would be cheaper.
Badtaste
« Reply #3 on: August 29, 2007, 08:09:27 PM »
Thank you.
Badtaste
« Reply #4 on: August 29, 2007, 08:21:53 PM »
Where would be the best place to get a new key and key slot?
« Reply #5 on: August 29, 2007, 09:20:25 PM »
If you are using the timing marks on the fly wheel and shorting the ecm advance wire to spec, you could have a couple of spark plug wires crossed, the slot would have to be epoxedy or use some devcon on the crank but get the key from a dealer.
