Installing a tach
  • 2200 Views
Jfreeze
Installing a tach
« on: September 03, 2007, 07:04:49 PM »
I did a search and couldn't find any info on people installing tachs so I guess I will ask.  I got a '94 2 dr that didn't come with a tach in the cluster so what would be the easiest way to go about installing one?
JF
Re: Installing a tach
« Reply #1 on: September 07, 2007, 10:27:34 AM »
I believe that you can swap in a different cluster as long as you get one with matching connectors.
Offline reb
  • 195
  • Victim of CRS--Can't Remember Anything.
« Reply #2 on: September 07, 2007, 03:20:29 PM »
I installed an aftermarket tach in an '85 Toyota, using some electronic knowledge and the factory schematic diagrams to figure out where to connect it.  If you have that knowledge or have a friend with it, that might be a reasonable way to go.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #3 on: September 10, 2007, 06:57:08 PM »
There's usually 3 or 4 wires you need to find when installing an aftermarket, power, ground, tach signal and illumination. Power, ground and illumination are at the radio, tach is in the engine bay, or behind the cluster in the connector.
kingzoo
« Reply #4 on: September 12, 2007, 06:52:47 AM »
   It would be easier to replace your gauge cluster with a cluster that has a tach.Easy to do,and easy to find for cheap.JMO.
Jfreeze
« Reply #5 on: September 12, 2007, 08:28:53 PM »
What clusters will work? Are there other 1994 models that have a tach or will a different year work?
jf
« Reply #6 on: September 13, 2007, 07:16:32 AM »
jf
The rare 1988.5-90 square vent CARBURATOR Tach dash can be made to work While the pilg is correct, the wiring is not the same.  You'll also need to ad in the VVS.  It's quite a bit of rewiring work on the dash cluster, but it can be done.  I have one in my 1994.
Otherwise, there is no factory tach option.  I bought mine new and I couldn't get one from the dealer.
