I need a measurement of a TracKick front end.
  • 1962 Views
Offline Jeff@TireBalls
  • 559
« on: September 04, 2007, 02:45:34 PM »
Can someone measure the distance on a Tracker or Sidekick from the front fender to front fender between the two red lines for me? (Does that make since?)
I'm trying to decide if an ARB or Shrockworks front bumper for a TracKick will be wide enough for my GV.
« Last Edit: September 04, 2007, 02:54:17 PM by Jeff@TireBalls »
2000 Grand Vitara Limited, 2" lift, 225/75-16 BFG KO's, 5.12 gears, Safari snorkel, roof rack.
1987 Samurai LWB, VW 1.9 Turbo Diesel.
Rodzilla
Re: I need a measurement of a TracKick front end.
« Reply #1 on: September 04, 2007, 04:40:20 PM »
A quick measure of my Shrockworks bumper on my Kick is 64" wide. That could be off by a bit, hard to measure exactly while on the vehicle. I would assume you will need new mounting points fabbed up to have it mounted on a GV. Cheers.
  • 559
« Reply #2 on: September 04, 2007, 04:55:11 PM »
Thanks! Is that outside to outside of the bumper or the actual measurement from the fender to the fender?
I get 66" on my GV so it may still work. I knew I'd have to fab brackets, I just wasn't sure the bumpers were going to be wide enough.
Rodzilla
« Reply #3 on: September 04, 2007, 05:09:26 PM »
Thats the very outside to outside edges. Looks like it might be a little narrow. My bumper is wider then the kick  by about the same amount as that pic in your first post. I think if the bumper was narrower then the vehicle it might look a little off. But, who knows ubtill you actully see one on there.
  • 559
« Reply #4 on: September 04, 2007, 05:14:46 PM »
Ya, I hate to buy it and be too narrow.  What to do, what to do.  :(
