No Start.
  • 1482 Views
Offline ghd23
  • 406
  • 1990 Tracker softop, Detroit Mi.
No Start.
« on: September 06, 2007, 04:41:44 PM »
Hi All.
  To start with, I'm usually pretty good when it comes to figuring out any problems with my Trackers. Not this time!
  I need help. Its my wife's DD, 1991 Tracker 2wd, 5 speed. It has always been hard to start in the rain, but once started it always ran like a champ.  Well 2 weeks ago after a good rain it started, I ran it for about 6 blocks, shut it off and it never started again.
  After checking all the usual suspects, I changed the fuel filter and it started right up, it ran better than ever. Drove it for 3 days, put about 100 miles on it. then it just shut off at a stop light. Hasn't started since.
I'm thinking ECM.  Any and all thoughts are eagerly welcome.
  Thanks Ahead, George.
If I Can't Weld It          It Can't Be Welded
Re: No Start.
« Reply #1 on: September 06, 2007, 04:50:20 PM »
Go pour a little gas down the t.b.i. and see if it runs for a sec or two.
Offline daddyizzle
  • 728
  • Colorado is still my home!!
Re: No Start.
« Reply #2 on: September 07, 2007, 07:48:17 PM »
I'm thinking ignition switch because it happens when it's humid out. It would be intermittent but would only happen in moist conditions at first and then eventually fail. I live in a humid area so I have had this problem on two or three older vehicles. You might just try swapping a good used one in. I don't know if the old sammy ones work but I have one. Changing the fuel filter is good but the fact that it started right up might have only been a coincidence.
-Adam
