Locker on a 4x2 questions
  • 2838 Views
Offline nuts4hotwheels
  • 169
  • Black Sunshine
« on: September 07, 2007, 04:23:36 PM »
I am sure that this has been asked before, but I did a search and learned alot but did not exactly find my answer.
I have a 1998 Chevy Tracker 4 door 2wd.  I miss my old 4x4 Sidekick that was lost in a tragic accident  few years ago.  I am wanting to outfit my Tracker for "light" offroad use (beach, a little mud and pulling my light boat trailer up the boat ramp), but mainly as a daliy driver.  I do not have the money or location to do a 4wd upgrade.   Long and short term cost is definitely an issue.
 ??? Are airlockers what I need or overkill?
 ??? Will lockers, such as lock rights, be okay on a daily driver?
 ??? Do lockers make tires and other parts wear prematurely?
 ??? I have heard that a 2wd with rear lockers do pretty weel compared to stock 4wd.  What is your opinion and/or experience?
Thanks for the help,
Brian
Black Sunshine
1998 4 dr Chevy Tracker 4x2 1.6L-16V
-K&N Performance Air Filter
-Thrush Glasspack -235/75-15 Pathfinder Trail A/P Tires  -Sony Xplod Cd Player -400W Visonik amplifier -2 10" Visonik Subwoofers *******************************
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
Re: Locker on a 4x2 questions
« Reply #1 on: September 07, 2007, 05:44:59 PM »
[  Are airlockers what I need or overkill?
Air lockers are not overkill they are just expensive.
LockRights are fine in a daily driver, they do make the truck handle differently so there is a learning curve.
Not so you would notice, as long as everything is working properly.
I have heard that a 2wd with rear lockers do pretty well compared to stock 4wd.  What is your opinion and/or experience?
A long long long time ago I had a 2wd F150 which I had raised with larger tires and a welded rear end. I did quite well with it running the fire trails and hills of northern Michigan. I will stick with my 4wd but if I only had a 2wd I would probably see what it is capable of.
Of course I would also be saving for a SAS conversion at the same time. Dave  ;D
Student of Now Master of Then
« Reply #2 on: September 08, 2007, 10:33:44 AM »
If you want to compromise you can get a Limited Slip locker.  Hawk Suzuki and Trail Tough both have them available.
  • 169
  • Black Sunshine
« Reply #3 on: September 08, 2007, 11:05:32 AM »
How difficult is it to install lockers?
Black Sunshine
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #4 on: September 08, 2007, 03:00:15 PM »
Have you thought about a spool, or welding?
  • 169
  • Black Sunshine
« Reply #5 on: September 08, 2007, 03:30:07 PM »
I do not want to get a spool or weld it, because it is a daily driver
Black Sunshine
« Reply #6 on: September 08, 2007, 08:30:41 PM »
Lockers are pretty easy to install.  I usually do the work on the bench in an evening.  There is a writeup around somewhere.
