nothing like overcoming an obstacle only to hit a wall again... question?
  • 10 Replies
  • 4421 Views
J-Ron
i got the toyota front axle in successfully!!!
now i am up to the daunting task of steering. i have the toyota IFS steering box, but no pump. i was wondering if it's no biggie to drive with no pump for a while until i get my hands on one? if i can, do i just plug the lines for the pump so there's no outlet for the steering box fluid?
Re: nothing like overcoming an obstacle only to hit a wall again... question?
« Reply #1 on: September 13, 2007, 03:04:47 AM »
It will be a real pain to drive without a pump.  Mainly because the ratio is much lower then on a manual steering box.  You should be able to adapt just about any pump though.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #2 on: September 13, 2007, 03:14:49 AM »
I assume that you mean that the steering box is a powered one but you just don't have the plumbing or pump for it yet...
It probably would be okay to run it for a little while - especially if you have the ports sealed against dust - but you probably need to find and hook up a pump to it.
Time to look for a salvage yard pump!
Ack
« Reply #3 on: September 13, 2007, 10:32:36 AM »
If it were me I would hook up one hose to it and fill it with fluid and then connect it to the other side of the box so you don't build pressure.
« Reply #4 on: September 13, 2007, 10:41:38 AM »
From the title I thought you were posting some cool trail pics.
Sorry, cant help ya with teh PS problem.
« Reply #5 on: September 13, 2007, 01:18:55 PM »
That is a pretty good solution.
J-Ron
« Reply #6 on: September 13, 2007, 09:24:48 PM »
thanks for the replies, but i've got more problems to pull out of the hat...
driveshafts... zuki to toyota axle doesn't fit, so a toyota shaft won't fit the t-case, right? so then would it be possible to fit the splines of the different shafts together?
« Reply #7 on: September 14, 2007, 03:24:12 AM »
You just need an adapter.  I know Rocky Road has one - http://www.rocky-road.com/zukdrive.html - and someone else had some too, but it's bed time and I can't remember. :)
Offline DRAGGINZUZU
  • 141
« Reply #8 on: September 14, 2007, 11:06:19 AM »
RockyRoad is still on backorder for the adapters, Try      www.rock4xfabrication.com
Its not what you buy but what you build
 Tony
« Reply #10 on: September 15, 2007, 12:44:31 PM »
See, I knew there was a couple other places making them.  :)
