What do you think??
  • 1973 Views
Offline museboy07
  • 641
What do you think??
« on: September 13, 2007, 12:37:02 PM »
Automatic tracker with 5.12 gears, high performance 2in exhaust, high flow cold air intake and 32s....would it turn the tires ok or not?
Re: What do you think??
« Reply #1 on: September 13, 2007, 01:18:08 PM »
It should turn them pretty well.  A few people are running Trackers with 32 and stock gearing.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #2 on: September 13, 2007, 01:33:32 PM »
Of course it will turn them. The 5:125's should help enough.
For what it's worth, the power loss isn't that bad. My old automatic(with the 4:62's) Tracker had 31's on it before it's death, and it was okay, a little sluggish at times, but it is a 4x4, so...
just buy your stuff and get er' done  :)
« Last Edit: September 13, 2007, 01:35:25 PM by Uncivilized »
Offline museboy07
  • 641
« Reply #3 on: September 13, 2007, 02:57:16 PM »
Right on brother...I think ill give it a shot.  It can't be no worse then my old tracker that was pushin 80lbs of compression from each cylinder.  I'd park on a slight incline and put it in gear and it would roll away with the engine turning...haha
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #4 on: September 13, 2007, 03:00:05 PM »
My Dad's rig has that exact same setup and it works very good.
     Kevin
   PS at 70 mph he is running 3k rpm
Offline museboy07
  • 641
« Reply #5 on: September 13, 2007, 03:20:28 PM »
So he has an auto with 5.12s and 32s?
