Reverse Switch
  • 2274 Views
Offline Uncivilized
  • 1469
    • Car Domain
Reverse Switch
« on: September 14, 2007, 07:41:29 AM »
My revese lights are not working, I've checked the bulbs they're good. I've looked around for the switch in the transmission, but can't find it. Can anyone help, and explain where I can find it?  :-[
1995 5-speed trans
« Last Edit: September 14, 2007, 07:58:38 AM by Uncivilized »
Offline ROSS
  • 1412
Re: Reverse Switch
« Reply #1 on: September 14, 2007, 08:11:19 AM »
look on the top of the trans. you can see the switch from under the zuk
Offline Uncivilized
  • 1469
    • Car Domain
Re: Reverse Switch
« Reply #2 on: September 14, 2007, 08:35:17 AM »
Is it closer to the bell housing, or the shifter? I can't see anything  :-[
I see a 2-wire plug in the front just under the edge of the floor and the firewall, it's really oily  :o I guess I have a leak somewhere  ::)
« Last Edit: September 14, 2007, 09:09:48 AM by Uncivilized »
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
Re: Reverse Switch
« Reply #3 on: September 14, 2007, 10:43:08 AM »
There are two switches on the transmission which use the same plug one is for the backup lights and the other is for the 5th gear EGR swich if you put the trans into 5th gear and the backup lights come on the wires are switched. Dave
Student of Now Master of Then
Re: Reverse Switch
« Reply #4 on: September 14, 2007, 04:21:04 PM »
If you have a later model trakick, then the tranny will only have the reverse switch.....they did away with the 5th gear switch, sometime in the early 90s (92 or 93, I think).
All samurai trannys have both switches.
The reverse switch simply passes 12V through it, when the tranny is shifted into reverse.....so you could probe the wires to see if you are getting 12V into and out of the switch.
MaD.72
Re: Reverse Switch 1
« Reply #5 on: February 17, 2008, 08:02:54 PM »
Anyone know if there expensible??
