will a sami trany fit in a tracker?
  • 2125 Views
dkevech
« on: September 16, 2007, 10:36:57 AM »
I have a question about a transmission i want to find out if a sami transmission will fit in a tracker. I want to do a motor swap and can get a sami transmission kinda cheap. and i just want to find out if it will work with little modification.
Re: will a sami trany fit in a tracker?
« Reply #1 on: September 16, 2007, 11:45:47 AM »
Physically you can make it fit.  But it won't bolt up to the 1.6.  Also you will need to replace your transfer case, as they Tracker has a married transfer case setup.
Offline museboy07
  • 641
« Reply #2 on: September 16, 2007, 11:55:58 AM »
Married?  Does that mean they won't come apart?
Offline blasterfan
  • 54
  • SHEAAAAA
« Reply #3 on: September 16, 2007, 02:33:58 PM »
there bolted togather... they will come apart, but to run it unbolted from a tranny it takes some brackets and some modds
best to stick with the tracker trans  ;)
85 tin top: spoa, weber, thourly, mud kings, no rust, shackels bumpers
88.5 soft top: spoa, lift springs, shackels, 1.6L, hybrid real axle, yota drivshafts, 5:13 gears, bumpers, winch, rear rad, 5 points and buckets, ltbs, lockers, custom exhaust, some trail scars and alot of army green paint
dkevech
« Reply #4 on: September 16, 2007, 07:35:27 PM »
well i was goin to put a vw diesel in the tracker right now i have a 16v and the vw motor has sami motor mounts and sami transmission already on it
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
« Reply #5 on: September 17, 2007, 10:43:28 AM »
In that case just swap the the whole drive train out and you would have better gearing options with the sammy t case.
Why would you want to swap out a 16v for the vwdiesel? Having the sammy t-case for better gearing options would be only thing you are getting out of this?
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
g-man
« Reply #6 on: September 17, 2007, 07:46:53 PM »
The vw diesel is a stronger engine than the 1.6 suzuki in more ways than one.
