Lift done, now I need alignment HELP.
  • 2671 Views
Cuthulu
« on: September 16, 2007, 01:53:38 PM »
I finished the 1.5" lift with Old Man Emu and coils spacers on my 94' Tracker.  I also replaced the rotors with Brembos and new Maxxis brake pads.  However when I read the shop manual it gives a explaination of proper camber followed with a line that says the camber cannot be adjusted on this vehicle. ???  I don't mind taking it to a shop to have it done but I am worried that now I'm  gonna take it somewhere and an hour later get told that it can't be done.
So I ask WTF?
I have to get it adjusted it's got to be at least 1.5 degrees +camber.  Any one have a problem getting an alightment done after a lift?
« Last Edit: September 16, 2007, 02:47:48 PM by Cuthulu »
Offline ChiTownZuk
  • 45
  • '92 2Dr Geo Tracker
    • ChiTownZuk Photo Bucket
Re: Lift done, now I need alignment HELP.
« Reply #1 on: September 16, 2007, 02:09:09 PM »
I took my Zuk to Firestone after my lift and they did the alignment with out a problem, I've got the 11/2" coil sping spacers from jeff1997 with 30x9.5x15 MT, had no issues getting it done
'92 2Dr, Geo Tracker D.D., hoepker's 1.5"F & 2"R Spacers, Black Grille Guard, w/100w Driving lights, KYB-G2 performance struts, strut mount flip, '91 Crown Vic rear shocks, BF Goodrich MT 30x 9.50 R15 RWL, Sirius Satellite,
'92 2dr, Convertible Tracker, Skid Plate, hoepker's 1.5"F & 2"R Spacers,
Cuthulu
« Reply #2 on: September 16, 2007, 02:29:46 PM »
So I did some forum seacrching (like a good N00b should have).  Found out about replaceing the top sturt mount bolt with these ezcam xr camber bolts.  The shop manual does not say what size those bolts are. :(
Anyone know FOR SURE what size they are?  I really don't want to pull apart the front again untill I have a set of these cam bolts.
Offline museboy07
  • 641
« Reply #3 on: September 16, 2007, 03:48:27 PM »
http://rocky-road.com/kicksus.html
Last product on that page...or any napa usually has them...just give them your vehicle info and they'll hook you up
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #4 on: September 16, 2007, 05:48:35 PM »
You can also buy them from www.SummitRacing.com or www.RockAuto.com.  Rock Auto had the best prices last time I looked.
They go by application since they aren't "normal" bolts.  Looks sorta like a 1-lobed crankshaft.
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #5 on: September 16, 2007, 07:00:33 PM »
or you could always womp the top mounting hole out so you can adjust camber there.....i also installed coil spacers...2"....and thats what i did
Cuthulu
« Reply #6 on: September 17, 2007, 04:45:15 PM »
Got the camber straightend out.  :D  Struck out at two Napas for the bolts so I went to a tire place that does lifts too.  38.00 later, had the bolts and was at home fixing the camber.  Now to pay for a real alignment.  Thanks for the tip AJMBLAZER of the rockauto.com.  That is one awesome site.  Can't believe I made it this far in life without that site.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #7 on: September 17, 2007, 04:54:06 PM »
No problem.  Been seeing it in the back of the 4x4 mags for a few years now and never looked at it.
Got pricing shocks and struts for the XL7 a while back and was able to get the good stuff from them for cheaper than the generic stuff locally...with delivery figured in!
Drag link end for my pickup?  $25 locally...$15 delivered on Rock Auto!
