another rear shock Q?
  • 12 Replies
  • 3040 Views
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« on: September 18, 2007, 07:10:01 AM »
ok...i currently have 2" coil spacers in front and rear, resulting to a little over 2.5" of lift in the front and a strait 2" lift in the rear...i put on the crown vicky shocks when i did the 2" spacer install....now im debating weather to put in 4 door coils or a 3" spacer in the rear....with that extra 1" of lift in the rear, am i going to need even longer shocks??
Offline 95tracker
  • 104
  • It'll fit Perfect!!!
Re: another rear shock Q?
« Reply #1 on: September 18, 2007, 07:28:32 AM »
Yes you will need longer shocks the ones you have now will prolly get you by until you get some but you take a chance of over extending them the ones that you need to look into are a Monroe 32305 they fit the front of a early 90s f150 they are about 31 inches long fully extended. which is about the closest to what you need.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #2 on: September 18, 2007, 07:30:41 AM »
I am also using these shocks, only thing I dont like about them is they are alittle stiff....
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #3 on: September 18, 2007, 07:35:00 AM »
anything else needed to be done to put these on??
Offline john1974
  • 617
    • Zuknation
« Reply #4 on: September 18, 2007, 07:36:52 AM »
Nope mine are in the stock position.
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #5 on: September 18, 2007, 07:39:22 AM »
sweet...thanks man.....what do you have for a lift??
Offline museboy07
  • 641
« Reply #6 on: September 18, 2007, 08:59:26 AM »
you haven't mentioned it yet but you WILL need the rear a-arm spacer
Offline john1974
  • 617
    • Zuknation
« Reply #7 on: September 18, 2007, 09:24:33 AM »
I have a 2 door tracker with four door boondox 3 inch lift springs in it.
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #8 on: September 18, 2007, 11:44:49 AM »
right on....that thing looks bad|removethispart|@$$....i see you didnt space your diff down either....i have 2" spacers all the way around resulting in 2.5" in the front, and my cvs are fine....good to know that i could put her up another half inch before any issues...
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #9 on: September 18, 2007, 11:46:25 AM »
and by the way museboy07....im already planning on the a arm spacer....know of any good links that show exact specs on these??
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #10 on: September 18, 2007, 06:02:42 PM »
Couple years ago someone posted up their autocad plans for a spacer.  Might do a search for them.
I've got the Calmini 3" lift on my Tracker and I'm running rear shocks off of a 2wd '98 F150.  The mountings are perfect for the Tracker and they're both slightly longer extended and slightly shorter compressed than the Calmini 3" shocks.
Offline museboy07
  • 641
« Reply #11 on: September 18, 2007, 07:36:00 PM »
Heres a link to one someone built.  Depending on how thick you want it you may want to change the thickness but all the hole measurements are correct.
http://babelfish.altavista.com/babelfish/trurl_pagecontent?lp=pt_en&trurl=http%3a%2f%2fwww.cabrito.suzukioffroad.com.br%2fUpper%2520wishbone.htm
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #12 on: September 19, 2007, 09:04:27 AM »
thats a pretty sweet link there...perfect blueprint....dont even have to take it apart....but a quick Q?...how thick should it be for a 3" lift??
