t-case help
  • 2772 Views
Offline locjaw
  • 2045
  • 22
t-case help
« on: July 09, 2005, 11:35:55 AM »
put t-case gears in kick couple weeks ago and this weekend we put the body lift on and now the 4WD high-nuet-low shift rod doesent move enough to get into nuet or low,got me pissed
anyone got any ideas
jason
Re: t-case help
« Reply #1 on: July 09, 2005, 12:36:26 PM »
Did you extend the T-case shifter ?
You need to add 2 or so inces to
get it back to where it was
Also, did you check the opperation of
the T-case lever before the body lift went on ?
Offline locjaw
  • 2045
  • 22
Re: t-case help
« Reply #2 on: July 09, 2005, 12:46:39 PM »
no didnt check but we had it in low just a couple of days ago and we are going to extend the levers but there is nothing in the way to keep it from shifting
jason
Re: t-case help
« Reply #3 on: July 09, 2005, 12:49:54 PM »
Take off the boot and knob, and get
a good look, it's probably hitting the body
Offline locjaw
  • 2045
  • 22
Re: t-case help
« Reply #4 on: July 09, 2005, 01:40:25 PM »
I have..... taken the shifter out, taken the detent ball out, taken out both switches, taken the top plate off to expose the ends of the shift rods, jimmied, beaten, pryed, cussed, jumped up and down put it all back togeather and taken it apart again. the only thing i havent done is shove my weiner in it(history tells me that that only makes things worst ::) ) I am looking for off the wall ideas  that someone not as pissed as me would have overlooked before i have to pull it out or just send it to the crusher
sorry but i needed to vent, thanks, i'm better now
jason
« Last Edit: July 09, 2005, 01:41:54 PM by locjaw »
Offline chopper
  • 57
  • go where no man goes
Re: t-case help
« Reply #5 on: July 09, 2005, 02:38:41 PM »
when i did my tcase drop i ahd a si milar problem where it woldnt go into low range all i did was take a pipe and put it over the shifter and pry it fortward ahs worked great fro a cupe years now
92'sas tracker 32" muds, oba, locked and loaded, 8274, toys
cardomain page http://www.cardomain.com/ride/553823
Offline ROSS
  • 1412
Re: t-case help
« Reply #6 on: July 09, 2005, 02:41:27 PM »
DID YOUR SHIFTER FORK SLIP OFF WHEN PUTTING IT BACK TOGETHER
ROSS
Offline 1bigtracker
  • 3409
Re: t-case help
« Reply #7 on: July 09, 2005, 02:42:05 PM »
getto, i like it!
stu
Offline locjaw
  • 2045
  • 22
Re: t-case help
« Reply #8 on: July 09, 2005, 03:13:30 PM »
we have had it in low about 5 or 6 times it always shifted nice now it dosent
jason
