Calmini t-case gears
  • 1522 Views
Offline museboy07
  • 641
« on: September 27, 2007, 07:47:54 PM »
Will the 4.24:1 t-case gears from Calmini only give me a lower range when I shift my t-case into 4lo?  Or does it give a lower range through 2wd, 4hi, and 4lo?
« Last Edit: September 27, 2007, 08:35:42 PM by Mikerpm4x4 »
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: Calmini t-case gears
« Reply #1 on: September 27, 2007, 08:35:00 PM »
low range only. high range the gears remain dormant.
