Zukiworld i need your help
  • 1917 Views
Offline suzi_n_sammy
  • 184
  • Rock the Sam
« on: November 18, 2004, 11:15:29 AM »
Aiight just got a new carb for the sammy. . . now i got most of the lines but i traded the core when i went to pick up my new one and could mark all the lines. i have three lines that i cant match up.
Top is the lines and the bottom is the right ( when faceing the grile) side. So if you could show me on that pic of the carb or just write it out that would be rad. the other line is coming off of the manifold right under the fuel line that goes to the top right corner. Thanks
You can take the Sammy off the trail, but you cant take the trail out of the Sammy.
  • 184
  • Rock the Sam
Re: Zukiworld i need your help
« Reply #1 on: November 18, 2004, 01:19:35 PM »
Aiight well i figured it out for the most part. all i need your help on now is if someone can run to their sammy and see is the line that goes from the intake  ( in front and to the right of the carb if you are facing the sammy head on ) to two vertical ports. One line runs right next to the fuel line by the head of the engine and the other to the intake but i need to know which one is on top and which is on the bottom.
