Engine & Transmission Removal
  • 2603 Views
Offline jerryp58
  • 449
« on: November 18, 2004, 08:49:26 AM »
Can the engine and transmission be removed as a unit (still bolted together) through the engine compartment?
Will the trans crossmember have to be removed (that's what I was thinking would be nice to avoid)?  Anything else odd?
I was thinking if I removed the hood and the electric radiator fan (possibly the radiator too) that I might be able to take both the engine & trans out together.  That'd make pulling the head, doing the front crank seal and replacing the trans (or having it rebuilt) much easier.
Jerry
Offline 1bigtracker
  • 3409
Re: Engine & Transmission Removal
« Reply #1 on: November 18, 2004, 09:32:10 AM »
i think that'd be pretty funny to watch some one try, but i don't see them really doing anything.  its not that bad taking the tans out anyway.
edit:  i took the trans out of mine in only a few hours on the floor with jacks.  and i have no body lift when it comes to that cuz i moved the engine up 3inchs.(sometimes i wish i had never done that)
stu
« Last Edit: November 18, 2004, 09:35:56 AM by 1bigtracker »
Offline SnoFalls
  • 1358
« Reply #2 on: November 18, 2004, 09:59:31 AM »
I think he's just hoping to get the eng/trans out in one unit for working without dealing with a remate with the eng/trans a typical engine-only pull would involve.
Jerry, you also didn't mention if the tranny was an auto or 5 speed.
Sry, I dunno the answer ... GL if you do try!
Offline jerryp58
  • 449
« Reply #3 on: November 18, 2004, 12:20:52 PM »
It's an auto.
I ask because I'm pretty sure that when I pulled the engine (6-cyl, auto) in my '68 Mustang that I pulled the trans with it (seemed easier).  And I know that a lot of car owners pull them both together.
I was thinking the biggest hurdle would be getting the transfer case past the crossmember.  I don't have that good a mental image of the t-case so it might be impossible.
I'd be surprised to find out that no one here has tried it, unless they know for sure that it can't be done.
Jerry
« Reply #4 on: November 18, 2004, 12:24:07 PM »
The cross member is 4 bolts,
just drop it and pull the whole thing
Remove the radiator/grill and stuff,
remove the top "core support" with
8 or 10 bolts (10mm) 6 on top and several
in the front by the lights
The rest should be easy to do
Good Luck
Offline explosivo
  • 3157
« Reply #5 on: November 18, 2004, 12:54:35 PM »
I agree with stu that if you're just removing the trans, just drop the crossmember and pull out the trans. It really isn't that hard, even without a body lift.
omghi2.us[/url]
