New Stereo Installation
  • 2728 Views
94zukiguy
« on: October 05, 2007, 10:47:13 AM »
Hello All,
I've been looking through archives and trying to find any posts specifically about installing a new deck in a Sidekick.  I'm surprised there wasn't more, but I guess most people have them installed instead of doing it themselves.
Because of my...um...situation...I have a new deck, but I'm going to have to do the install.  Seeing the brain surgeons they hire at Best Buy, I'm fairly confident that I can do it myself.  But I did want to ask the forum if there's anything I should look out for or be aware of.
I did read that one person said you should replace the stock speaker wire, but at this point, tomorrow is going to be a very busy day working on the car already (ball joints, window regulator, stereo, speakers) and I'm hesitant to start getting into running wires.  Maybe next weekend.
I guess my biggest question is how do you get the stock deck out?  Sadly, I didn't get this deck from Crutchfield...but I did get an amazing deal.  We'll see if it's worth it...
Thanks for your help!
Offline Carnage
  • 2453
Re: New Stereo Installation
« Reply #1 on: October 05, 2007, 11:20:47 AM »
for my 96 it was
take out ashtray... two screws
take off 4 AC knobs, pop off plate carefully... two more screws
then the whole panel should lift off to reveal the deck
94zukiguy
« Reply #2 on: October 05, 2007, 11:26:22 AM »
Wow...I hope it's that easy with my '94.  Thanks, that's great to know!
 ;D
Offline Carnage
  • 2453
« Reply #3 on: October 05, 2007, 01:13:56 PM »
hope so too
the earlier models are typically easier than the older ones
phloop
« Reply #4 on: October 05, 2007, 07:46:50 PM »
As for replacing the speaker wires, you really only need to do that if you are adding an amp. That, or your anal about your install. And a in dash unit will not over tax the stock wires as it does not have very much power.
Just toss the reciever in the dash and enjoy.
94zukiguy
« Reply #5 on: October 05, 2007, 08:00:51 PM »
Well, my audiophile friend is encouraging me to install an amp (since I have one available).  I'm not much on the thump side of things, but since an amp is probably in my future, it's something to consider.  I won't worry about it until the day comes, though.  Thanks for the good word, I wouldn't have known stock wires would be taxed by an amp...
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #6 on: October 06, 2007, 09:13:53 AM »
You really only need an amp if you're installing extra speakers, like a woofer or two in the back. The head unit will be enough for the stock size speakers. I replaced the rear 4" speakers with 6.5" in the same spot, and it works great, it's more than enough to tune out the noisy kid in the back  :-X If you still have the stock cassette player, I'd buy a wiring harness adapter instead of cutting your factory harness, they're like $12, and they're color coded to the aftermarket head unit, so you just match up the colors, and plug it in :)
Offline Carnage
  • 2453
« Reply #7 on: October 06, 2007, 03:27:18 PM »
I would go with the harness too.  the lowest ive seen is $7 on ebay and thats shipped to your door.
tracker8v4x4
« Reply #8 on: October 29, 2007, 05:05:09 PM »
i would defanantly get the harness and as for the amp if it lows it will be rca cables and highs u can use stock wires to the amp but larger out of it
