Bigger Tire on Original 15x5.5 wheel
  • 4672 Views
96kickjx
« on: October 07, 2007, 05:31:15 AM »
Hey guys, I have a pretty good set of 235/75 R15's, Uniroyal Liberator A/T, cheap, but damn good tires btw! I have em on a set of 15x7 chrome wheels. I'm gonna be getting the General Grabber AT2's in a few months or so, 31's, and I was wondering will my 235's fit on the original 15x5.5 wheel or are they to wide, I looked it up on tirerack.com and it said that size can't fit on anything smaller than a 6" rim. Is that true, or can I fit them on the 5.5"? They're really good tires and I don't just want to get rid of them.
Offline museboy07
  • 641
Re: Bigger Tire on Original 15x5.5 wheel
« Reply #1 on: October 07, 2007, 07:33:20 AM »
I used to run 235s on my stock rims for more then a year...no problems at all except they rubbed the frame a little on full lock
Offline RHodge
  • 523
« Reply #2 on: October 07, 2007, 10:49:47 AM »
I ran 235 on stocks the only proplem I noticed was the centers wear faster, but if you run lower tyre pressure it helps
Ryan
Offline olija
  • 770
    • Check out my cardomain
« Reply #3 on: October 07, 2007, 12:37:38 PM »
I ran 235/75's on my stock rims for almost a year, no problems whatsoever. It only rubbed the driver's side framerail on extreme left hand turns..but only enough to scrape the paint off, nothing serious.
Offline j2custom
  • 197
  • Suzuki's rule!
« Reply #4 on: October 07, 2007, 06:16:37 PM »
I have run the 31x9.50 swampers on the stock wheels and it worked good.  They did rub the springs at full lock turning.  HTH ;D
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #5 on: October 07, 2007, 09:49:39 PM »
I ran 33 x 9.5's on the 5.5" rim  ;D
96kickjx
« Reply #6 on: October 08, 2007, 06:52:05 PM »
Cool thanks ya'll. when I get the 31" General Grabbers, I'm gonna go ahead and put my 235's on the stock wheels, just don't want to get rid of them. Thanks for the info.
Orlando
Mudjockey#1
« Reply #7 on: October 09, 2007, 07:24:43 AM »
I have 33" x 10.50"  BOGGERS on stock sami rim but it has 2" spacers to fix the rubbing problem!  I run about 18 psi in the rears and about 20 up front and daily drive it! ;D
Offline satan inside
  • 68
  • bodylifts are for rednecks
« Reply #8 on: October 12, 2007, 11:22:40 AM »
i used to run 235/75 on my stock rims no problem. can air down really low without losing a bead. just lower your air pressure to avoid wearing out the center of the tread
