New Sidekick and a few questions?
  • 2220 Views
Samzuki
« on: October 09, 2007, 01:06:23 PM »
I recently sold my lifted Samurai and purchased a very clean 97 Sidekick JX 4DR 4x4 with automatic transmission and 16 valve engine. It has 153,00 miles. The truck seems to run great. :) I will be using it as my daily driver to save fuel instead of my LX450
On the drivers side of the shift lever there is a little button that slides forward and rearward. I cannot feel or see any effect when I push this button. What is this for?
When I start up I see a light on the dash that briefly says overdrive Off. This turns off when the car is running. As i accellerate, I hear(and see on the tachometer) the transmission shift 3 times. Is the overdrive working properly? My tachometer says approximately 3400 rpm at 70mph.
Is there a link to an online service manual and owners  manual for my vehicle?
What kind of fuel economy can I expect from a stock Sidekick like mine?
« Last Edit: October 09, 2007, 03:40:18 PM by Samzuki »
Samzuki
Re: New Sidekick and a few questions?
« Reply #1 on: October 11, 2007, 07:22:54 AM »
Does anyone here know the answers to my question?
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #2 on: October 11, 2007, 09:15:02 AM »
The button that's normally on most automatic shifters is either overdrive on/off or perhaps a sport/normal mode so that it will hold the gear for longer for more acceleration.
It should only shift 3 times once you're rolling, which would put you into 4th gear (4-speed auto is probably what it is).
1993 4-door Sidekick
4.24:1 t-case
Offline joezuki
  • 133
  • zukiworld rocks!
« Reply #3 on: October 11, 2007, 09:26:04 AM »
If you are talking about the button on the side of the shift lever, it is the overdrive button.  when you are driving & you push the button & let go, the o/d off light should come on.  To the right of the shift lever should be a rocker switch with  n a/t p   on it.  you should leave it on "n"  if you switch to "p", the tranny will shift at a higher rpm for more power & worse gas mileage.The word " power" should also light up on the dash.   I'll use it to merge onto a freeway during rush hour.Your shifting sounds correct as crikeymike described. 3400 at 70mph seems high, but i'll have to check that on my way home.  I get 21mpg around town & 25 on the highway in my '92 4 door JX that also has the 16v engine.  If you do find an online service manual.... let me know about it.
zukx3
« Reply #4 on: October 11, 2007, 06:52:15 PM »
I have a '95 Sidekick, manual transmission, so my mileage runs a bit better - around 23-25 in town, and as much as 30 on the highway.  I've got about 125K mileage on it.
As for the manual - you might want to check Goodwill stores - some of them even put their books online.  It's amazing what you can find for $4.99.
« Reply #5 on: October 12, 2007, 05:07:11 AM »
Online Service manuals
http://www.suzukiinfo.com
