Perfect tire size??
  • 9 Replies
  • 3166 Views
87 sammi
Perfect tire size??
« on: October 11, 2007, 05:15:48 PM »
I have an 87 samurai with a 6" lift and i am currently running 33x12.5's. is that too big or too wide cause they rub really bad. I just wanted to see what everyone thought or has on their rigs because I may want to go to a different size. Thanks for the help!
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
Re: Perfect tire size??
« Reply #1 on: October 11, 2007, 08:20:50 PM »
No 33/12.50's are only appropriate on a Sidekick. As it so happens I have a Sidekick so send them to me and I will send you some little tires for your Tipsy Samurai.
Student of Now Master of Then
« Reply #2 on: October 11, 2007, 09:08:57 PM »
Heh.  :)
Where are they rubbing at?  On the springs or on the body?
Offline Amilla
  • 1076
« Reply #3 on: October 12, 2007, 06:00:10 AM »
3.75 backspaced rims should make it fine, my old boss had that combo, the only time it rubbbed was when he ran into a deer and pushed his bumper into the tire.
Amilla
Mudjockey#1
« Reply #4 on: October 12, 2007, 04:57:20 PM »
I'm running the same amount of lift as you and i run 33" x 10.50 Boggers on stock sami rims with 2" wheel spacers.  My biggest problem arises when I go to stuff the fronts, i get good hard rubbing that knocks the fender flares off on the bottom.  Hope this helps! 8)
« Reply #5 on: October 12, 2007, 10:24:18 PM »
That is why I was wondering where it was rubbing.  I run 33x12.5 on my SJ with 3.5" rims and cut my fenders out to get rid of the rubbing.  :)
Course, I have a 410 so the springs are 1.5" inboard on each side...
Offline goodyz
  • 133
  • Turdzuki.
« Reply #6 on: October 12, 2007, 10:30:31 PM »
Ha HA HA!! LMAO! :laugh:
-goodyz
87 sammi
« Reply #7 on: October 16, 2007, 06:30:43 PM »
They rubbed on my bumper so i trimmed that but they still rub on the springs. Maybe i will try the spacer idea.. THANK YOU ALL!!
« Reply #8 on: October 17, 2007, 01:47:26 AM »
Spider Trax makes some nice spacers.  You can also get some off of E-Bay for Fords, but they make you change your lug nuts over to standard.  If you get an e-bay pair make sure they include both lug nuts and mounting nuts.
Offline LWB Samurai Joe
  • Diesel samurai's rule!
« Reply #9 on: October 22, 2007, 11:51:46 AM »
I like BIG tires, but whatever you feel comfortable with is the perfect tire size really.
2001 VW TDI Bora
1987 Turbo diesel LWB Samurai
1987 Toyota HZJ-60
