Where to buy speedo gears
  • 1734 Views
burke
« on: October 14, 2007, 12:45:05 PM »
Broke the teeth off of my speedo gears (both the big one on the output shaft and the small one that leads to the cable).  I was being careless when pulling bearings on my transfer case and busted them right off. :'(
Does anyone know who might sell both of these?  Also, since I have to replace them anyway, does anyone sell different ratios so I can get my speedo to match my 31 inch tires?
Thanks,
Re: Where to buy speedo gears
« Reply #1 on: October 14, 2007, 02:49:35 PM »
I get all of my o.e.m. stuff from trail tough, next day ups and you get the correct stuff.
Offline daddyizzle
  • 728
  • Colorado is still my home!!
« Reply #2 on: October 14, 2007, 04:28:35 PM »
Oops!!! :police: :police:   Sounds like you forgot to pull the speedo gear out before separating the two halves. That's easy to do if you try to wing it.  I have an extra set of stock ones in pretty good shape. They work anyways. I see very little wear on them. P.M. me with an offer if the vendors want too much for theirs. Mine are from a samurai.
-Adam
« Last Edit: October 14, 2007, 05:19:46 PM by daddyizzle »
Offline SnoFalls
  • 1358
« Reply #3 on: October 14, 2007, 05:00:36 PM »
speeo gears from an automatic (that had 4.62 diffs) will correct for 31's nearly dead on.
