Suzuki Swift,1.3 DOC
  • 2290 Views
Luke
« on: October 15, 2007, 12:07:01 PM »
While searching for engine parts,I keep seeing thing listed for samurai and swift 1.3.Will a swift DOC engine bolt up in a samurai? ???
  • 6603
  • 69
Re: Suzuki Swift,1.3 DOC
« Reply #1 on: October 15, 2007, 02:33:00 PM »
Yes, the 'twin cam' 1.3 found in the Swift GT will bolt to the Samurai Transmission and will use the same engine mounts. The major mod is that the firewall needs a bit of a trim for the distributor, however, some have mixed and matched ignition parts to make the dizzy work without a firewall modification. There is also a 1.3 8 valve engine that was in the Swift and Metro that is even more similar to the Samurai engine.
Good luck, eric
