whining tranny
  • 10 Replies
  • 4480 Views
Offline jaybyrd92
  • 30
  • 1992 Suzuki Samurai JL
whining tranny
« on: October 18, 2007, 06:43:51 AM »
I recently had to replace the tranny in my '92 JL. It shifts tight and works fine but It has a high pitched whine coming from the tranny while it is idling. It quits when you push the clutch pedal. This leads me to believe it is the throw out bearing. I have tried to change my clutch adjustment but it keeps on whining.
 I had just replaced the throw out bearing in the old transmission, so , I put it on the one I just installed. Was this a mistake? Do I need to drop the tranny again and replace the throw out bearing?
Could it just be temporary and eventually quit?
  I have tried adjusting the clutch but I can't get the whine to stop.
        jaybyrd92
Never use money to measure wealth.
Luke
Re: whining tranny
« Reply #1 on: October 18, 2007, 07:34:22 AM »
the throwout bearing shouldn't be doing anything when idiling,sounds like a transmission bearing problem to me,when you push in on the clutch the tranny input stops turning
luvmysammy
Re: whining tranny
« Reply #2 on: October 18, 2007, 07:41:22 AM »
Luke is right, i have rebuilt both my trannys for my sammy, and with the whining, it most often was the front countershaft bearing, but i had some other bearings in the trans that were bad as well. still had whining after i replaced my throwout bearing, so i tore it apart! check samuraiparts.com for a trans bearing kit, mine was like 80 bones with shipping and all, cheapest i found on the net, hope this helps.
Offline daddyizzle
  • 728
  • Colorado is still my home!!
Re: whining tranny
« Reply #3 on: October 18, 2007, 03:31:34 PM »
You might try putting the transfer case in neutral and shifting through the transmission gears. There's a possibility the noise is actually in the transfer case. If the noise goes away with the transfer case in neutral while you shift through the gears, then your transfer case is probably making the whine. Worth a look.
-Adam
Offline jaybyrd92
  • 30
Re: whining tranny
« Reply #4 on: October 21, 2007, 06:02:05 PM »
Thanks for the advice , I tried what you said Adam but it is not the transfer case. I think the tranny I bought has a dry bearing. Looks like I will have to drop the tranny again. I see a tranny rebuild in my near future.
                 Thanks,
               jaybyrd92
Offline urbanwheeler
  • 696
Re: whining tranny
« Reply #5 on: October 22, 2007, 12:08:16 AM »
mine is whining, but it is in all gears except 4th, and it makes a loud grumbling sound when the engine is idling and the clutch is out. I know it is the bearings, but the problem is that I cant seem to find a 4wd transmission in the junkyards down in southern california, and the transmission in it isnt a good one to rebuild, as there was chunks and flakes of metal coming out of the oil when I changed it last. I even found a piece of a washer (most likely off of one of the gearsets) on the magnet of the drain plug.
luvmysammy
Re: whining tranny
« Reply #6 on: October 22, 2007, 12:16:59 AM »
i have a good geared trans, needs a bearing set and the cheapest set is from samuraiparts.com if u would like, i can sale u mine, it wines a little, but thats cause of the bearings, easy to rebuild too! i've rebuilt about 6 of them.... lemme know!
phloop
Re: whining tranny
« Reply #7 on: October 22, 2007, 09:23:21 PM »
Think you can PM me some pointers on ripping the tranny apart? I need to do this myself and after looking at the FSM I now have some questions on talking pats of the tranny apart.
luvmysammy
Re: whining tranny
« Reply #8 on: October 22, 2007, 09:35:49 PM »
let me see what i can do about sending u a step by step video on taking the trans apart..... get back with u soon
luvmysammy
Re: whining tranny
« Reply #9 on: October 22, 2007, 09:54:59 PM »
the file is way to large, i can email it to u. i verbally explain and show u how and what to unbolt to take the trans apart, pm me with your email and i will send u the video i just made.
  • 696
Re: whining tranny
« Reply #10 on: October 22, 2007, 11:40:37 PM »
Mine is a geo tracker, so I don't think that a samurai trans would bolt up too well :P I am still debating as to whether I should put a new transmission in it or not. The engine is starting to smoke, and the body, paint and interior is kind of rough. The paint is only starting to look bad on the hood(the paint came off in the shape of the top of the engine).  It would make a great off roader project, but its days of being a nice car have been gone since I hit a deer with it.
