T-case gears
  • 2690 Views
BigRedZuki
T-case gears
« on: October 21, 2007, 12:19:18 PM »
i was wondering do the gear reduction kits for trackicks lower the low and high range in the t case? i was wondering this, cause since nobody makes 5.83's anymore, so then if the t-case is lowered it would restore power in high range, for bigger tires.
Re: T-case gears
« Reply #1 on: October 21, 2007, 12:42:41 PM »
No, just the high range.
BigRedZuki
Re: T-case gears
« Reply #2 on: October 21, 2007, 02:31:59 PM »
so they lower the high range???
Offline cj
  • 1276
  • I drive a really big ATV
Re: T-case gears
« Reply #3 on: October 21, 2007, 02:32:49 PM »
They lower low range only.
BigRedZuki
Re: T-case gears
« Reply #4 on: October 21, 2007, 02:37:59 PM »
ya thats what i thought.
lowering high and low range is a good idea for a kick though.
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: T-case gears
« Reply #5 on: October 21, 2007, 05:23:43 PM »
Yeah, but the case physically won't accept a different size high range gear, so you're SOL, unless someone "creates" a brand new t-case for sidekicks, which would probably cost a fortune.
1993 4-door Sidekick
4.24:1 t-case
BigRedZuki
Re: T-case gears
« Reply #6 on: October 21, 2007, 06:13:28 PM »
on rocky roads website they have lowering gears that come with a new case piece if that does anything.
http://www.rocky-road.com/kickdrive.html
Offline museboy07
  • 641
Re: T-case gears
« Reply #7 on: October 21, 2007, 07:59:43 PM »
Hey bigredzuki.  Your sig is kick ass!  I thought it wasn't real at first but it seriously shows my IP address and my ISP!! Thats so cool.
BigRedZuki
Re: T-case gears
« Reply #8 on: October 22, 2007, 06:32:04 PM »
thanks if you go to danasoft.com you can make one and put it in your sig. p.s. it only shows your info to you so it makes you think that everyone can see it.
